DIY plasic without fancy chemicals by LinuxH4x0r
This is how I make "plastic" for my projects.
All you need is:
-Aluminum foil
-Styrofoam (expanded polystyrene)
-Iron
-A towel or ironing board
-Common sense and safety
WARNING: DO NOT ATTEMPT TO THIS INSTRUCTABLE. IT INVOLVED HIGH TEMPERATURES THAT COULD CAUSE SERIOUS BURNS, PROPERTY DAMAGE, OR EVEN FIRE. THIS PROJECT MAY ALSO GENERATE HARMFUL FUMES THAT COULD CAUSE PERMANENT BRAIN DAMAGE.
I AM NOT LIABLE FOR WHAT YOU DO WITH THIS INFORMATION!
I hate disclaimers (but I hear getting sued is worse).
Step 1: Preperation
Lay down a towel or ironing board on the surface you want to work on so it doesn't get hot or burn. I recommend using an old one that you don't care about because it will probably get burned.
Plug in the iron and let it get hot. The temperature doesn't matter, but if it hotter it will melt faster. I'm not sure but when it gets hotter it probably releases more fumes.
Take your Styrofoam (I use packaging from a printer and spacers for bottles) and break it into smaller pieces (about 3"x3"x2"or about 80x80x50 mm) The size doesn't matter, but it makes it easier to melt.
Charger_06 says: Jan 12, 2008. 6:03 PM
you can also make plastic with milk and vinegar ill get the recipe and post it
TheAmazingJonny says: Mar 5, 2011. 7:36 AM
I use those same ingredients to make fried chicken! But it use high temperatures and could be fatal if done wrong so I am not willing to post it.
LinuxH4x0r (author) says: Jan 12, 2008. 7:43 PM
Cool! I'd love to see it.
Coffeebot says: Mar 6, 2008. 8:22 AM
I posted the milk/vinegar plastic a few months ago: http://www.instructables.com/id/Homemade-Plastic/
How resilient is your plastic? I would figure it still has a bit of brittleness that styrofoam is famous for.
rbneville says: Apr 3, 2011. 10:50 PM
@Coffeebot using milk and vinegar makes cheese lol
Broom says: Mar 5, 2011. 7:02 AM
While melted polystyrene is toxic, mild dizziness and eye irritation is the worst it really has to offer - not lethality. Plus, moderate ventilation - don't do this in a closed room, duh! - is enough to prevent this level of toxicity. The smell of melting styrene is noticeable long before the adverse side effects become a risk. Source.
And styrene vapors are not as light as O2, so they don't rise to the ozone layer. You're probably thinking of the HCFC gases often used to expand polystyrene into styrofoam - but once the styrofoam is made, there's really reasonable nothing that can be done to prevent release of these gases, anyway, so it doesn't matter if they're released by ironing, or UV exposure, or decomposition in a landfill.
LinuxH4x0r (author) says: Mar 6, 2008. 3:07 PM
Cool! I might try that. My plastic is pretty hard. It depends on what you start with, and how thick you make it.
littlechef37 says: Apr 30, 2008. 8:17 PM
This is a good idea because it keep POLYSTYRENE **looks back at that big word and wonders if he spelt it right** out of the lakes and land fills.
Broom says: Mar 5, 2011. 7:01 AM
LinuxH4x0r (author) says: Apr 30, 2008. 8:44 PM
Thanks! polystyrene (yep, its spelled right) is such a waste. Too bad I can't put this in the green contest
cyc4015 says: Jul 14, 2008. 6:47 PM
honestly, this is a horrible idea. I don't mean to sound like a jerk, but polystyrene is very toxic when heated. the vapors released from it can be lethal, and cut a big fat hole in the ozone layer. it's a nice idea, but not a healthy one,
Broom says: Mar 5, 2011. 7:00 AM
LinuxH4x0r (author) says: Jul 14, 2008. 7:14 PM
No, I totally understand what you mean. I did this out of boredom and desperation. I had recently moved and all of my stuff was back at my other house 1200 miles away. Agreed, bad idea
stephenniall says: Jan 2, 2009. 2:20 AM
In replyto Koil_1 underneath me i use wal-Mart shopping bags for rope and pen holders etc after melting and carving with the soldering iron lol
Koil_1 says: Dec 30, 2008. 3:18 AM
Wal-Mart shopping bags also work pretty well as a source of plastic. I thought I was the only one who did this sort of thing... I guess not.
Cann0n says: Oct 19, 2008. 10:57 AM
It's not as bad as some make it out to be. Like all projects that involve hydrocarbons, work in a well ventilated workspace . Seeing the black smoke is what is the major environmental issue with polystyrene, as well as being carcinogenic. One of the ideal uses for this method would have to be the production of very cheap 'Sliding Gloves' for skateboarding. I haven't tested them with this method. Most slider gloves are made out of a hard polyurethane material jsut glues to the palm of a glove. If this material is thick enough to provide little friction and durable for that type of abuse, you have yourself "Worlds Cheapest Sliding Gloves" at your hands.
LinuxH4x0r (author) says: Oct 19, 2008. 4:57 PM
Good idea. Yes, these are extremely hard and would be ideal for sliding gloves. The only disadvantage is that they are brittle and might crack on impact
schmidty says: Jul 1, 2008. 8:47 PM
nice idea, but i would probably make napalm with my styrofoam instead... try makin it with cheap plastic stuff like from the dollar store.
Lego man says: May 18, 2008. 3:54 PM
Nice, its like my plastic instructable.
LinuxH4x0r (author) says: May 18, 2008. 4:44 PM
Thanks!
bob111 says: Mar 18, 2008. 4:55 PM
nice job go forward/
LinuxH4x0r (author) says: Mar 18, 2008. 5:04 PM
Thanks! Have you seen my new ible? Check it out, and if you like it rate it
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
