Step 4Done and in use!
Here you see my Ibanez, Heritage 575, Hagstrom Swede, and National Delphi filling it up. (yes they're all left handed)
Total cost was less than 30 dollars. Similiarly manufactered items go for $50 to $100 in music shops.
Good luck
Glad to be of help!
The kit is made by a company called saga - here is a link to their page - but I bought mine on ebay. The quality was better than I expected although one day when I have time and $ I will update some of the components. It comes unfinished and so I kept the natural look with some clear spray lacquer and it looks pretty good!
Have fun!
Components are obviously not top drawer quality, but considering the price, what do you expect? As for sound, *it* sounds great. The problem here isn't the guitar but the player. :)
As for whether I'm satisfied with it - I'll be getting one of their tele kits one day soon.
http://www.guitarcenter.com/Hercules-Stands-GS412B-Single-Guitar-Stand-102339512-i1142251.gc
Got some idea's?? I could use some help!
Greets Dereck!
Sorry if you got problems reading my comments, I'm from the Netherlands and my engels isn't so good...
Try raising the lower bout rails like I did with my design. Each side of the V
would fit with the rails in between. Then put it at the end of the rack resting
on a padded side rail for the headstock in between the side rail and one of the teeth. That should work.
The back upright would have the cross piece the teeth goes into
the front upright piece would have a padded side rail to the upright
that will have the teeth. This is the padded side piece I was referring to
earlier. The headstock of the flying V would rest on that padded side rail
right on the end.
If you look at:
http://www.instructables.com/ex/i/3B0F5556D7731028931A001143E7E506/
There are 4 pieces you need to cut to make the sides. On the PVC fittings I just bought, the pipe goes 3/4" into the fitting. If you call the piece you need to cut on the far left piece A, and the next one B, etc.....(Note that if your fittings have a different clearance you will need to fix these numbers)
Piece A = 4 1/8"
Piece B = 7 5/8"
Piece C = 5 3/4"
Piece D = 5 5/8"
I did not figure out the uprights, but I would figure between 29" and 30"
For the record, the pieces with the exception of the glue which I have, ran $24.67, and the place I bought them was not the most inexpensive place in town. Handy, yes, inexpensive, no.
Very cool project!
