DIY Sanding Machine.
2,214
69
9
Posted
Introduction: DIY Sanding Machine.
when i was trying to make my ring (chek it out if you haven't seen that instructable yet :D) i had to do a lot of work by making rhe ring flat and soft. i was playing around with a small motor and burned my finger because i touched the moving part of it. the idea was born... what if i glue some sanding paper to it?
the result was better than i hoped :)
Step 1: Finding Materials
you will need:
-sanding paper
-a motor
-a power source (9 or 12 v is enough for some kind of metal and for wood)
-glue
-something to cut with
Step 2: Making the Upper Part
cut out a piece of sanding paper just big enough so you can stuck it around the motor.
Step 3: All the Sand Came Of? What Now?
leave the old piece on it and just place another one (bigger than the previous piece) on top it. you can repeat that till you think it gets too bick and then you remove the old piece and replace it for a new one
Step 4: Putting Things Together
i use a 9v or 4 3V powersources. i prefer te 3 volt because it has more power, but the 9 v fits perfectly into the motor so it is easier to hold
Step 5: :)
good luck with building it and if you liked this instructable please chek out my other instructables :) leave a comment if you have any points of improvement or questions :)
  • Sew Warm Contest 2018
  • Gluten Free Challenge
9 Comments
Do you think it would be possible to use a 4.5v motor + battery pack?
i think 12 V, at least it can handle 12 V
Nothing better than inspiration born of pain. ;-)
This could be even more useful if a speed control circuit such as a P.W.M. is used as metal and wood machine best at different spindle speeds.
yea but the fun part that its easy to make and i just had to stretch my arms to get the materials, i dont have that kind of stuff in my room :'D
I understand:
we roeien de riemen wij
I normally do the sandpaper trick on a nail then slap it in my cordless drill
This is very cool because I have two scrap motors that would work perfect for this
