DIY Smartphone Tripod Mount/case
Published
Introduction: DIY Smartphone Tripod Mount/case
In this project we're gona make acrylic phone tripod mount/caso for your smarphone. Better to watch the video for FULL TUTORIAL.
Step 1: Measurements
-Start with buying a plexi, I find my in the neighbour's trash so I pick it up and clean as much as possible.
-Then take your phone and measure it very precisely or it won't fit in the case.
-A better option is to look up your phone's specification on a google and write it down.
-Start drawing measurements on a plexi with waterproof marker, make it a bit bigger than original dimensions so you can sand it down precisely.
Step 2: Cutting and Putting Things Together
- I used my jigsaw to cut all pieces out.
- And don’t forget to use safety glasses.
- Try to cut slowly and accuracy, if you will go too fast, the plexi will melt and your cuts will be very bad.
- When you cut all pieces, try to smooth all the edges and corners of the rectangles or they won’t fit together later.
- The best option to remove marker from plexi is a sort of alcohol, because it won’t melt plastic such as acetone.
- I used hot glue gun to match all parts together.
- Try to do this step as quick as possible because you have a few seconds before the glue start to cool down.
- When the glue cool down remove left over glue on the case with x-acto knife.
- Smooth all the edges and corners of the case until they look very nice and non-sharp on touch.
- For extra smoothness I used sand paper type 100.
Step 3: Camera Hole
-Now we need to position where our camera holes is.
-I used 20 mm drill from stainless to cut a hole out.
-Do this gently because a lot of heat is produced when drilling and you don’t want to melt your case.
-Use dremel machine to enlarge hole for led, this is optional and I drill it just for aesthetics.
-Now we need a cutting mount to cut front plexi on a dimensions of our touch screen, do this slowly and carefully.
-I drilled 2 holes on the bottom of the case and cut two different threads for two different screws because not all tripods have the same thread.
Step 4: Finishing
-If you want to you can paint your case with your favourite color like I did, don’t forget do this in well-ventilated area.
-And there you have it. I record a few videos and they were so stabilized, they look like they were recorded from a professional camera. I made one from the wood for my younger brother and he was also impressed and the best thing is that I made all that for free.
https://www.youtube.com/watch_videos?video_ids=D7t...
Thank you for watching, please subscribe, like, comment and you can watch my second video where I built cassette tape to MP3 aux converter.
https://www.youtube.com/watch_videos?more_url=&vid...
    • Casting Contest
      Casting Contest
    • Flowers Challenge
      Flowers Challenge
    • Woodworking Contest
      Woodworking Contest
