Introduction: DIY Smoker
turn a old freezer or fridge intro a smoker.
Step 1: Materials
A old freezer or fridge
some bricks
some hand tools
a good length or two of dryer vent ducting
a reciprocating saw
a item to use as a smoke baffle
and a lid of sorts to cover your smoke box/pit
Step 2: Prep the Appliance
Remove all peripheral items such as the compressor and thermostat.
Step 3: There's No Going Back After This Step
Trace the spot Where your going to insert the ducting into the unit then use a 3/4 inch butterfly bit or hole saw to start a spot for the saw. Use the saw to cut around the out line and insert the ducting.
Step 4: Start Diggin.
dig out the spot where you will put the fire box and dig a trench for the ducting that will be attached to the unit.
Step 5: Install Components
Put the unit into place and connect the ducting. Build a brick tunnel to start off the beginning of the trench and insert ducting into this.
Step 6: Mop Up Work
Add a baffle to the unit over the smoke hole. Back fill the trench put the lid over the smoke box and it's done.
Step 7: Fire It Up!!!!!!!!!!
Start a fire in the smoke box and build up a really good coal bed. Put a whole bag of soaked chips of your choice on the coal bed and put the lid in place. Now sit back and watch the smoke start to roll.
Green Electronics Challenge
