3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY spray paint
Step 5Fill with old paint
fill with old paint
If you're like me, you have heaps of old, half-used, miscellaneous cans of paint hiding in storage somewhere. Time to put that paint to good use!
If you are mixing paint make sure you are using like-kinds of paint (latex/acrylic with latex/acrylic and oil paint with oil paint), do not mix oil and latex paints! Mixing dissimilar paints is not advised as it's essentially oil and water. Though, it may produce some interesting results. In fact, ignore my warning, try it. Tell me your results!
Drop your old spray paint marble into the bottle first. then carefully pour your paints into the bottle and fill about 3/4 of the way full. You're going to need a funnel. Since regular paint is quite thick, I diluted my paint with a little water after it was in the bottle. I ad a ratio of about 6:1 paint to water. Experimentation here will produce different results. A thicker paint may not drip as much, but might require more pressure in the bottle (see next step regarding pressurization).
Seal bottle with nozzle cap and shake well to ensure an homogenous mix of paint and water.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
758
Author:mikeasaurus(michaelsaurus.com)
I'm the Play Editor here at Instructables! I like mixing old ideas with new and reusing things not for their intended purpose; the results are sometimes messy but always fun. I also write the thrift-...
more »
