3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY stylish sofa-bed
 The purpose of this project is to build a sofa that can be also an emergency bed (quite confortable..) and also act as home theater case.
In my room the shape of furniture was particular, so I adopted the sofa shape to it.
If you are interested, you can view the list of my not-yet-realized ideas on my blog
NEW: I published the instructable of the whole attic
Step 1Materials
Materials
  • 5 pieces of wood (multilayer or MDF), the size of wood depends on the size of the sofa. I used 110 cm x 120cm (43 x 47 inches)
  • Screwdriver (better if electric)
  • Electric saw
  • Lot of screw
  • Metal bars to connect wood pieces
  • Sheets of paper (better if they are big)
  • Tape
  • High density Foam (10 cm)
  • Low density Foam (3 cm)
  • Lot of fabric
  • Thin plywood
69 comments
1-40 of 69next »
Jan 11, 2012. 12:41 PMFlatLinerMEDIC says:
If this was heatetd I would pay 18000 euro!!
Jan 12, 2012. 11:36 AMFlatLinerMEDIC says:
Oh i meant to say lire....=/
Jan 22, 2012. 3:35 PMomalachowski says:
You could add a heated blanket under the fabric layer. I don't think this would pose any more of a fire hazard than a heated blanket normally would. (Which is to say not much, but if you find yourself on fire I was wrong.)
-Olaf
Dec 13, 2011. 11:09 AMfoodcity1234 says:
cool! can you make a version of it for a regular wall, but with some storage on the sides?
Dec 13, 2011. 11:36 AMfoodcity1234 says:
i dont even need the wiring or anything. just the frame design and the cushion design
Jan 22, 2011. 5:14 PMlpkid1057 says:
how did you know the length of the curved board? Did you just attach it to one end and then bend it into place and then cut it?
I suppose you can use a tape measure along the curve...
Jan 22, 2011. 5:18 PMlpkid1057 says:
How did you sew the fabric together on the foam seat? I think that is black fabric sewn around the two layers of foam as you described, right?
It looks really professionally done, so how can I make mine look that good? lol
Jul 3, 2011. 8:35 PMtinker234 says:
wow i wonder if i made a middle arm rest that came up a bulit in remote be cool great project
Jul 23, 2011. 4:01 PMjoshpaz1 says:
im moving into a new house n my room doesn't have much space so this gave me a great idea to mcguiver a bed using this method and put my stereo under it! and somehow put the jacks like on a plate screwed into the plywood
Sep 28, 2011. 12:33 AMwowfabin says:
Nice build, how much did it end up costing you?
Sep 26, 2010. 10:36 AMresaxox says:
Oh wow, I love this. You should really modify it for a regular wall. It's a fantastic idea! :)
I so adore it.
Sep 27, 2010. 5:03 AMresaxox says:
I'll keep an eye out in hopes. :)
Jul 27, 2010. 2:44 PMzacharyliles says:
Where did you get your foam??
Jul 16, 2010. 11:11 AMfuteng says:
Any idea on how this could be modified for a regular wall? And is it comfortable? good for the back?
Jun 20, 2010. 8:48 PMcnegrea says:
how remote control works?
Jun 16, 2010. 4:06 AMbluenebe says:
Wow. That is perfect.
Apr 16, 2010. 7:31 PMdarkclaw42 says:
 Wow! Just what Ive been needing for the upcoming attic to theater conversion!
Mar 4, 2010. 11:34 AMJezter Long says:
 Nice instructable, Thank You.  One question about the Stereo compartment.  Shouldn't that be ventilated?  Cool air in, hot air out?  When You open it after using it do u notice any heat coming out?
Feb 28, 2010. 1:14 PMsilverrowan says:
How comfortable is the foam? Do you think this would be adequate to sleep on long term?
Feb 25, 2010. 5:16 PMtroytoews says:
 that is a jig saw isn't it ?
Feb 25, 2010. 8:46 PMmosquitoloco says:
I would add an intractor and extractor of air to prevent high temperatures in the amp, nothing expensive or big... any computer fans could do the work... and you can add white grills to hyde the fans or much cheaper you can make several holes to hide it...
Anyway good Job!! it´s look great and seductive... a good "night" weapon!
Feb 26, 2010. 7:21 AMdarlos says:
nice work
1-40 of 69next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:derte84(Genteautoreggente!)
