Step 6Add walls to the sofa and do some painting
First cut the thin plywood with the same height of the sofa.
Attach the plywood to the center part with 2 screws (as shown in the picture).
Then SLOWLY bend the wood until it touch the corner of the sofa (I take 5 minutes to do it. If you do too quickly the wood can brake)
Attach the plywood to the corner of the sofa with 2 screws.
Repeat the steps for the other part of the sofa.
You can also use remaining parts of the pieces of wood to add a door to your home theater box.
Paint the hometheater box with black paint (better if it's matt) and the plywood with white paint.
I also put some grey fabric on the floor of the home theater box to hide the metal bars.
When the paint is dry you can cover the cutted square with a piece of wood.
TIP: If you must acces inside the sofa you can simply remove 2 screw from the corner
I suppose you can use a tape measure along the curve...
