I built this taser for my diy video podcast. (check out my shirt!) I thought I would make an instructable to enter in the flashlight contest. The design I used gives a jolt of 1200 volts which I promise you can really feel! In the video we have an exclusive interview with Geoff Desmoulin from Spike TV's show "Deadliest Warrior" where he talks about the science and effects of tasing people.
Please check out my other instructables
Remove these ads by
Signing UpStep 1Materials
The shopping list is on the downloadable pdf. The only things not included there are: 9v battery, 9v batt connector, housing (mine was a flashlight) copper circuit board, a small amount of wire and a switch.
Total cost in parts should be around $30
Tools required are:
drill
1/32" , 3/64" drill bits ( I also used a larger bit for mounting the switch but the size will depend on your switch)
soldering iron and solder
wire strippers and snips
copper etching kit
Some tape
a clothes iron
I used an angle grinder with a zip disk to cut the circuit board
If you don't know how to solder, check out this guide:
http://www.instructables.com/id/Soldering/
If you don't know how to etch copper, here are a few good instructables, I used the methods described in the last one.
http://www.instructables.com/id/Sponge-Ferric-Chloride-Method-Etch-Circuit-Bo/
http://www.instructables.com/id/The-Saltwater-etch-process/
http://www.instructables.com/id/Etching-a-circuit-with-toilet-bowl-cleaner/
http://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/
there are also several great instructables on it.
see link below
simple Fluorescent inverter project
