DIY Wood Case for Arduino LCD Shield
6,344
62
7
Posted in WorkshopCardboard
Introduction: DIY Wood Case for Arduino LCD Shield
About: I am always making electronic stuff. I like to do Arduino projects best. more projects coming soon!
This is an upgrade for my project "DIY ArduinoLCD shield" go check out how to make the shield at my channel!
This is an easy project to make, you only need 2 parts and some tools.
Step 1: Parts
You only need 2 parts for this project and some tools.
The bolts I used was 4cm but they are to long, I think 3cm is perfect.
you need:
wood plate
4x nuts
8x bolts
Step 2: Cuting
Cut out 2 same size plate for the case top and bottom. The case can be as big as you want it to be, but mine is L9,5cm x H6,5cm
Step 3: LCD Hole
Hold the LCD on the wood and mark where you want the hole, than cut out where the LCD is going to stick out.
Step 4: Drill Holes
drill holes that the screw fits in at every corner on the top and bottom plate.
Step 5: Finishing
Put the screws in the holes and screw it all together. You can paint it a nice color to.
thanks for watching! go check out my other projects to :)
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    7 Comments
    Nicely done! Look forward to seeing more from you!
    thank you! I'm soon publishing more
    Thank you for the neat instructable. I like it a lot.
    Rima
    thank you so much :)
    Very pretty case! Definitly an awesome way to take your Aduino project to the next level.
