After three days of testing we can confirm the wood doesn’t scratch the iPad, the iPad doesn’t fall over when you tap the screen and you can use it horizontally while charging :)
Materials:
- Piece of nice wood (130 x 80 x 24 mm or 5.1 x 3.1 x 0.9 inch if you prefer)
Tools needed:
- Saw
- Drill
- Large diameter drill bit (we use 19mm)
- Sandpaper
Remove these ads by
Signing UpStep 1Make a 130 x 80 x 24 mm wooden block
I've seen stands that do not hide the ipad button.
Is this because of the wood strength? So if I use a hard wood, can the groove be shallower?
Is it possible to have a higher edge on the back and a lower on the front?
Thanks for your comment and idea!
http://kingbillyprojects.wordpress.com/2011/12/13/wooden-ipad-stand/
I value my fingers very highly and hate working with short lengths of wood like this that get my digits so close to a spinning blade.
I do plan to make one of these, but I think I'll start with a longer piece of wood, use the table saw's cross slide while cutting the slot and then cut it to length.
Great instructable!!
If you make a nice version of the wooden iPad stand, will you share pictures :) ?
