3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DMX-512 LED Controller with LED Display
Step 7Plug It All In & Test
First Look the whole circuit over, check for solder bridges, loose wires, or wrong connections.
Insert ICs and Test:
  • The end with the dot on the IC lines up with the notch on the end of each socket.
  • Line up the pins and press in firmly.
  • Check it over
  • Once the chips are inserted and its looked over, go ahead and apply power. Remember if no 7805 has been installed 5 volt is the maximum input voltage, if the 7805 was installed, minimum 7 volts are required, up to 32 volts, which could be further increased with a different 7805 and heat sink.
  • The display should light up and respond to button commands.
  • Once the display has been tested and working, it is a good idea to hot glue the ribbon cable to the PCBs, otherwise the wires could break or come undone while handling.
  • Optional: connect to a DMX signal, it should switch from stand-alone to DMX mode, and display the address.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
61
Author:ChromationSystems(www.chromationsystems.com)
Designing electronic creations from microcontrollers, LEDs and anything else I can pull out of a dumpster and make use of. Check my Profile
