Step 11Breakout board and Testing
To power anything more substantial than a single RGB LED, a breakout board is used.
A board is chosen depending on the LED setup to be used. They come in Resistor regulated Common-Anode, Resistor regulated Common Cathode Configuration and Constant-Current Regulated board.
The Supplied Resistor Regulated boards are meant for multiple small LEDs or a few high-wattage LEDs, R4, R5, & R6 are large enough for a 2 or 3 watt Resistors. MOSFETs included with the boards can handle up to 46 watts each.
For very large units, I have had good success with the BuckPlus Line of constant current regulators. See Here
When ordering a kit, either decide what kind you will need or Contact Us for Help choosing.
Testing:
To test if the PCB is working properly attach the included Common Cathode RGB LED to the
" - R G B" Header.
- First Attach a 100-500 ohm resistor in series with the common cathode( ground, its longest lead)
- Then wire up the rest of the leads to the correct header pin. See Diagram.
Add Comment
