Step 6Prepare Interconnects
If board interconnects are being not being used skip this step. To continue the rest of the steps some interconnects will need to be wired. Part Pictures and Explaination
To start this step you will need to know how long you will want your wires for the various attachments. All of them are all made pretty much the same so I will only explain how to make the 6-wire interconnect with dual stranded wire. As pictured below.
- Start with 3 equal lengths of dual stranded wire. Total of 6 wires.
- Strip a 1/8" of insulation off the ends of the strands.
Crimps will have to be attached to one end of the wires.
I have an External Crimp Tutoral Page Covering the Process
Once you have 6 wires with one crimp on each wire. Get a housing that is the right size.
Each crimp should slide into the housing and snap into it. They only fit in one way. Just press them in until they "snap"
The rest of the interconnects, power, mic, sound potetiometer, DIP Switch are all made the same but with a different size housing.
Add Comment
