DOTR8 (My Custom TR8)
802
5
44
Posted in PlayKnex
Introduction: DOTR8 (My Custom TR8)
About: Hello, my name is Ondrew. My main interests all lie in design: from mechanical to digital to sound to graphic to... Past me finds it important to go to www.legoblockshell.org to help prevent Shell from da...
I've been experimenting with making my own turrets for a while, and I think I've finally found a way to build one differently from the original that gives it some advantages.
These are the instructions to build it.
Anyways, some of the advantages are that it:
Is sturdier than the original TR8.
Doesn't use an abundance of two-slot grey connectors.
Is really pleasing geometrically to build.  (I could just stare at the internals of the turret for hours. :3)
Is compatible with all the other TR8's.
Get the exact same range as a regular TR8.
I would recommend this to anyone who wants to have a turret that is different.  Mount this on your Turret Rifle today!
Take note that 4-slot green connectors don't have to be used for the majority of the barrels; you can also use red 3-slot connectors, or anything that has more than two slots, but no larger than a five-slot connector.
I'm working on a turret pistol that will use this turret.  So far, I have only posted pictures of it here.  Keep it quiet, though. :3
Step 1: The Parts
Here are all of the pieces  that you will need to build this turret.
Part Count:
Connectors:
Green Four Slot Connectors: 40 (Can be substituted with Red Three Slot Connectors or even Yellow Five-slot Connectors)
Red Three Slot Connectors: 8
Orange Two Slot Connectors: 8
White Eight Slot Connectors: 5
Tan and/ or blue clips: 8 (You just have to have eight little nubs; it doesn't matter which kind; they can be mixed or all of one type.)
Rods:
Green Rods: 40
Blue Rods: 8
White Rods: 8
Keep in mind that it's possible to substitute many things for this turret.  If you don't have enough pieces: experiment!
Step 2: The First Layers
In these steps, you'll build the energy transfer or mini firing pin thingy and give the turret structural support in the back.
When you're done with this step, you should just stare at it for a bit.  That spiral pattern looks pretty cool, doesn't it.
Step 3: The Next Layers
Now you'll build the barrel that leads up to the bullet lock.  Just follow the pictures, and if you have any questions, please ask.
Step 4: The Last Layers
Here you will build the bullet lock and finish the turret's front.  I hope this turret serves you well!
 (O,O)
<(IIIII)>
    I   I
-DarkOwlKnex
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    44 Comments
    this doent fit the WASP (war assault semi-automatic pistol)
    I'm glad it went to good use. :3 It works best for guns, though.
    Thanks. I see that you're viewing all my instructables right now. :P
    Then you probably didn't know that I'm just back from 2 weeks vacation =D
    I'm now watching all new knex stuff, so I'm also watching your work (and I like your work :D)
    No, I didn't know that (but I was wondering where you went). :P And thanks!
    Your ball machines are absolutely amazing, by they way. I would try to get into that, but I don't think that I have enough pieces. :I
    That's the biggest problem for knex builders: parts. I don't know how many parts you have but for a normal size ball machine you need at least 7 - 10 thousand pieces.
    You can try to build only lifts and then post instructions if it's a new concept.
    Oh, maybe I'll do that sometime. :P No idea where to start, but I could try.
    Oh, and although I don't usually keep track, you are my 600th comment. :P Congratulations and thanks!
    Haha no problem! You just made my 1243rd comment :D
    You're welcome, and I forgot to mention it, but I like your profile picture. Derpity derp derp derp.
    You're welcome; I posted this so people could use it! :D
    Dude this is awesome do you mind if I use this turret "mag" in a turret gun ?
