Step 6CONNECT USB / PS/2 ADAPTERS
Most USB keyboards come with a basic USB to PS/2 adapter, if not you can get them here for $3.99. Plug this adapter onto the end of your USB keyboard (effectively giving you a PS/2 keyboard).
Step 2:
Now plug the USB to PS/2 adapter into the PS/2 to USB adapter. I know this sounds silly, but Instructables member Grendel tells us that the larger PS/2 to USB cables interpret the PS/2 signal, reformat the data into USB HID packets, and send them on to the PC. Normally you can't have 2 USB Hosts on the same bus but this hack gets around that.
Step 3:
Plug in one of the USB connections into a PC. When you have the keyboard functionality properly then plug the other USB connection into another PC. If everything goes as planned then you should now have the power of two PC's at the tip of your fingers.... use this power wisely.
| « Previous Step | View All Steps | Next Step » |
5
comments
Add Comment
Add Comment
