Double your productivity by connecting a single mouse to two computers! It's simple: one mouse, two USB connections, infinite possibilities. Each click of your pointer finger will be twice as powerful with this mouse mod. This is a low cost, no soldering, HOW TO that will double your clicks per hour in minutes.
Remove these ads by
Signing UpStep 1MATERIALS / PARTS LIST
Vendor: Radio Shack
Cost: $9.97 or less
Notes: You only really need one mouse but you need two serial cables. I ended up just buying an extra mouse because at RadioShack they are cheaper then a serial cable. Old serial mice are just llaying around everywhere waiting to be used, they can often be found on ebay.com for $1 or less.
Part: QVS USB-PS2Y USB to Dual PS/2 "Y" Converter
Vendor: J&R
Cost: $14.99
Notes: You are going to need two of these. There are cheaper options but this is the only one that I know works for sure.
Part: Duct tape
Vendor: Any will do.
Tools: A sharp Xacto blade and/or wire cutters.
| « Previous Step | View All Steps | Next Step » |
Motherboard = main board that everything connects to including the CPU
Monitor = the visual interface (the screen)
Computer = housing for the motherboard, drives, and component interface cards i.e. the video card.
i hope that cleared things up.
also you may want to only connect one set of power wires to the mouse. right tnow you are giving it double what it needs and that aint too good. atleast you had pictures so PROPS! =D
CPU = brain
Motherboard = spine
Computer = skull or body!
note. i dunno whether it would cause files to corrupt be good for someone to try with a cheap tacky usb stick lol
