3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DPScope - Build Your Own USB/PC-Based Oscilloscope
Step 21Assembly Step 10: Diodes
Next in the row are the clamping diodes. These components need more care than the resistors.
• Make sure you insert them with correct polarity (correct orientation); the negative end is denoted by a black stripe around the diode body. The silkscreen outline also shows a (white) stripe – this is the side the black stripe must lie. Note that the orientation is not the same for all diodes.
• Diodes are quite sensitive to heat. Thus try to minimize soldering time. The best approach is to first solder only one end of all diodes, then the other end – this gives them enough time to cool down in the time between.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:womai
