(1) Place the socket on the board as shown in the big picture. Note the position of the notch on the left side of the silkscreen outline – make sure to orient the notch on the socket to the same side. This will make installing the chip less error-prone.
(2) Turn the board around an solder only two of the corner pins as shown in the zoomed-in picture below. The reasons is simple – two pins diagonally opposed will securely hold the socket in place, but still allow you to make corrections.
(3) Press the socket onto the board and re-heat both of these solder joint – this allows the socket to sit flush against the board. Visually inspect the socket to make sure this is really the case.
(4) Only now solder all the other pins.
