To make photos more pleasing, many people use a diffuser.
You could buy one, but most people make them They are homebrewed with everything from a simple sheet of paper to plastic cards and even fancy "origami" folded papers.
This is yet another diffuser, but I think it shines by it's simplicity. It's made from something almost all photographers have in the bottom of a drawer... a film canister.
Remove these ads by
Signing UpStep 1Measure your flash and cut the canister
Then grab your canister, a box cutter or X-Acto knife and cut a slit down the side of the canister. Make sure that slit is barely wider than your flashes stalk.
A (somewhat unnecessary) addition is to fit a bit of reflective material, ex. tin foil, behind the flash to bounce back more light. Again, this may be unnecessary because the white plastic will accomplish the same thing.
But check out mine with hundreds of free colored inserts for colored flashes that work as filters.
http://www.instructables.com/id/Free-Flash-Diffuser-with-hundreds-of-free-colored-/
