3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DSLR macro on the cheap!
There are already a few of these but I wanted to post my own version as im rather happy with my results! :)
The great thing about this project is that you can make it as long/short as you yourself require (longer tube=closer macro) AND it will fit with any lens made for the canon EOS series! :)
one thing to note, if you make a long tube it will allow you to take photos SUPERCLOSE, but your "focus-range" will be minimal, meaning that if the object your taking a picture of has any curves, only a tiny portion will be in focus
GALLERY! http://snelpiller.deviantart.com/gallery/29084300
Things you will need!!
Cover for your DSLR Body
Cover for your DSLR lens, as in socketcover.
A tube of some sort, I used  a roll that used to have giftrope on it (anything that dosent let through light can work)
A hot glue gun
A dremel or other tool for making holes in your covers
Black Electrical-tape
*if wanted*
a bottle or other tube to fit over the "lens-extension" to make it prettier :)
Step 1CUTTING! WOO!!
CUTTING! WOO!!
Use a dremel tool, or other method, to remove the center of both caps, get rid of all plastic that isnt holding the lense/camera.
These caps will be Glued onto the ends of the tube, allowing the tube to fit into your DSLR body like a lens would.
Then the same goes for the other end of the tube, but with the socketcap that allows you to put your lens into the extension.
33 comments
Jun 4, 2011. 2:25 AMjcoronel says:
Good work !!!
Aug 4, 2011. 1:56 AMasridhar1 says:
I used a rustoleum spray paint can's cap, works perfect for my Canon. Cheers to a great instructable!
Feb 27, 2011. 8:17 AM8bit says:
Any chance of seeing a (big) gallery of things you shot using this?
Mar 7, 2011. 1:17 PMstrath says:
I'm making one of these, but I'm also adding a fotosharp adapter from my astroimaging rig, and the tube is part of a t-ring adapter from the astroimaging setup as well.
Fotosharp adaptor: http://www.zerobyzero.ca/Starstruck/?page_id=264
I'm going to try using crazy glue and then black silicone sealant to attach the modified lens cap to the tube to ensure a sturdy, light-proof connection.
Feb 17, 2011. 9:07 AMspeedhump says:
So Mr Gluegun strikes again! I ask what kind of person would want to mess up an expensive DSLR in this manner? Go buy the real thing. M42 extension tubes cost $6 - an adapter ring to fit M42 tubes to most makes of camera - old or new cost between $22 and $35 post free. Here's a clue to make it really easy:-
www,FocalPrice.com
Feb 17, 2011. 3:20 PMriff raff says:
I agree. Hell, I probably have an old set of M42 tubes around here I'm not using. :-)
Still, nothing beats a decent 100mm macro lens and off-camera strobe.
Feb 18, 2011. 2:53 AMspeedhump says:
Not sure your set-up will catch a decent snowflake portrait though! To get in to this MICRO- PHOTOGRAPHY field I have been following a website instruction more or less and have ordered 3 sets of extension tubes, and a Sony NEX-5 adapter ring from the dealer I mentioned, Totalling $48.62.delivered. A decent PLAN achromatic X4 microscope objective (lens) set me back about $64 and I am still missing an adapter to connect the lens to the tubes - and a means of adjusting the focus. Here a stripped down and modified slide copier that has helicoidal adjustment may be used to cut down on cost. I am broke but I hope I don't have join the Gluegun Gang!
Re. original theme:- Also please note that many body caps are a snap-on fit even over a bayonet fitting. Using such in Mr Snelpiller's PRO setup might result in an expensive repair bill when the lens falls off.
Feb 18, 2011. 8:16 AMspeedhump says:
Regarding adjusting aperture: It's true some lenses cannot be stopped down when detached from the camera. But if you get a $25.34 42mm (Pentax) thread adapter, there plenty of these lenses about very cheap, Canon FD lenses are also a possibility but BEWARE NOT ALL FD lens can be stopped down when operating solo. e.g. the chrome ring breach lock FD S.M.C. lens aperture locks up. It's a great field of photography to enter. Go for it!
Feb 18, 2011. 8:04 AMspeedhump says:
What you have won't cut the mustard, I'm afraid. There is one Canon lens that will do it without any extension tubes or bellows by going to 5X magnification. The Canon MP-E 65mm macro costs about $1000 - yes! an amazing price to match it's amazing capabilities. Not sure what model Canon DSLR it is made for.
What I am getting set up for leads into real micro-photography i.e. greater than 1:1
follow www.its.caltech.edu/~atomic/snowcrystals/photos/photos.htm for more information - but don't follow his sources - it will cost a bundle going his route - maybe his university has the budget for it - I don't
Feb 17, 2011. 11:27 AMspeedhump says:
Sorry Mr Snelpiller - Don't burn yourself with that gluegun!
Feb 17, 2011. 3:16 PMnekotali says:
hey snelpiller,
just wondering: how is the macro effect achieved? is there a certain length of the tube you're supposed to cut it to?
looks great though and you've done well!
tali
Feb 18, 2011. 1:10 AMnekotali says:
thanks heaps - will report back if/when I try this for myself :)
Feb 17, 2011. 2:06 PMrobbied says:
There is always a lot of satisfaction from making something yourself. I took a luxeon LED torch, added a power switch and external battery and turned it into a powerful bike headlight. Sure I could have bought one, but the equivalent cost was about 10 times what it cost me.
Feb 17, 2011. 8:54 AMMother Natures Son says:
I wonder what would happen if I put my macro lens on one of these things...
Feb 5, 2011. 2:09 PMJakeg says:
Amazing... I am looking forward to buying my first DSLR... :) I just noticed, you can actually see the camera's reflection in the tip of the ball-point pen.... Great Job!
Jan 30, 2011. 1:26 PMGhost Wolf says:
Amazing very cool never thought this possible!
Jan 30, 2011. 7:35 AMtigerbomb8 says:
one thing is you should blow out the dust from the tube any time you put it on
Jan 29, 2011. 1:14 PMynze says:
Cool! I'm gonna try it with my 50mm prime!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:snelpiller
