loading
this gun truly is a step ahead of most knex gun on the site. with the abilty to be a sniper (long range combat) and a shotgun( for short range combat)you can take down almost any opponent( with the exception of the sr-v1 of corse!). the ammo i have right now is:
sniper round
shotgun round
and the immportant deer slug
the credit for the bipod for the sniper goes to KillerK(took it from his sr-v1)
credit for the handle and trigger system(though i moded it) goes to the_ burrto _master.
big edit!!!!!!:
i have changed the gun a lot. now trigger system that uses the hammer on the back to cock the gun. and a popout banneut(sorry about spelling)also i made it so the sides of the gun hold 6 deer slugs. aslo i put a grip on the gun and the trigger for the banneut is right by the grip. instructions are being made hurray!!
please note that the only reason my instructable is full copyright is because i dont want people to plagerise this instructable! feel free to make the gun! and a better but
Step 1: Barrel
this is the longest part. it also uses up most of the yellow connectors you need for the gun. so make this part first because if you cant make this then there is no reason to make the rest of the gun.
pic 1: make 17. make sure to make one like pic 2 and 3.
Step 2: Trigger System
just follow the pics.
Step 3: Butt of the Gun
look at pics
in pic three notice the connection points.
Step 4: Bipod for Sniper Verson
same as the sr-v1. go look there.
Step 5: Loading and Fireing
follow the pics.
in the shotgun ammo, you put lots of blue rods in the barrel with the round.
Step 6: Have Fun
have fun with your new shotgun! dont shoot at anything that could tell the popo! dont forget to rate! please leave comments!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
you mean &quot;<em>J</em> Money&quot;!<br />
This so owns the SR-V1
nah, the rifle and the DD-27 do!
dont shoot yourself with the dd-27... it hurts when you do.
i learned that the hard way....
yep so did i XD
dude this is awsome !!! but hey work on the stock/butt/whatev u call it ...<br/>4.5 * * * * '<br/>
try making the rifle, or better yet the DD-27 or my sniper. both are better then this and use less pieces.
remember i told you about that m1 garand gun i'd make out of your dd 27,<br/><br/><a rel="nofollow" href="https://www.instructables.com/id/knex-rifle_7">ere it is</a><br/><br/>yes this is spam.<br/>thats because i love spam.<br/>
thats sweet
if you like this, you should make the rifle. its 10 X better.
I thought this was the rifle
well, kinda. the rifle is mostly a modded version is this gun, and it has it's own instructable.
OH whoops nevermind.
Where?
Sorry, but this gun really isn't innovative. It does the exact same thing that the sr-v1 does, and it has the same trigger as the_burrito_master's crossbow. Innovation, would be something new that works well.
1. so the sr-v1 is compleaty different. 2. i said that in the intro.
The sr-v1 is not completely different, it uses a slingshot system as does this one. That seems pretty similar if you ask me.
this uses more of a crossbow type thing. and they look nothing alike. also the slingshot system has ben used many times before the sr-v1.
I never said they looked alike and this cant be more of a "crossbow type thing" because there are no limbs. All this gun is, is an extended version of he_burrito_master's crossbow.
IN A SLING SHOT THE BULLET IS ATACHED TO THE RUBBERBAND AND IS HELD BACK BY YOUR HAND. IN A CROSSBOW THE RUBBERBAND WOULD BE HELD BACK BY YOUR HAND AND SHOOT THE BULLET WHEN YOU LET GO OF THE RUBBERBAND. THEY ARE COMPLETY DIFFERENT!!!
I never said it was a "slingshot", but a slingshot mechanism, which it is. A slingshot mechanism is when the bullet is launched directly from the rubber band, there is no ramrod or hammer.
no it is not. it is a crossbow mec. there is a difference!
No there isn't, they are the same, each holds back a rubber band and releases it when its fired.
in a slingshot the bullet is held back in the trigger system and the rubberband is attached to the bullet. <br/><br/>in a crossbow the rubberband is held back in the trigger system and the bullet is in the barrel <strong>SEPARATE FROM THE RUBBERBAND</strong><br/><br/>that is how they are different.<br/>
The bullet is not attached to the rubber band in a slingshot system, look at the sr-v1, the bullet sits in front of the rubber band, it's not connected.
you must have not made the SR-V1 because thats not how it is loaded. i thought that to before i made it. search "how to load the SR-V1" and you will find a instructable on it. the rubber band is hooked up to the bullet.
leave dsman1 alone the SR-v1 is totally different idiot
o my gosh. i know! what ever. i will get rid of the line that says it is knex innovation.
also i think this is knex innovation because it can be a sniper and a shotgun and has a new type of ammo.
I don't see how a shotgun can turn into a sniper by using a bi-pod. The gun isn't a shotgun anyway, its not pump action and that bullet only spreads once it hits the target.
OK LOOK. NOT ALL SHOT GUNS HAVE PUMPS. THE FIRST SHOT GUN DID NOT HAVE A PUMP. IF YOU ACTULY LOOKED AT THE LOADING STEP YOU WOULD SEE THAT THE GUN GETS LOADED WITH A LOT OF BLUE RODS ALONG WITH THE ROUND. ALSO IT IS A SNIPER BECAUSE USING THE SNIPER ROUND YOU CAN GET REALLY GOOD AME AND RANGE. THE BIPOD ONLY HELPS WITH GIVING IT ACCUREY!!!
I understand that not all shotguns have a pump, but you shouldn't say your gun is a shotgun, because it isn't. What you should say is, you can load this gun like a shotgun. That also makes it no different from other knex "shotguns". And did you really think using caps lock would help you win this argument?
haha. the defenition of shot gun is this: a gun that uses the explosion of the gun powder( would be the ram rod in knex) to fire lots of ammo called shot. so teckenly this would be more like a shotgun if you filled the barrel with bbs.
I like the fact that you make up your own definitions. A shotgun is only loaded with one bullet, called a shell. The shell is filled with BBs. Your gun would be more like a shotgun if you design a shell that held small pieces.
i will work on that design.
no i did not think using caps would help me win. so what you are saying is that the first shotgun was not a shot gun and just was loaded like a shotgun?
No I never said that either, I said your gun is just loaded like a shotgun. Stop making up garbage, you know your wrong.
no i am not wrong.
how far does it shoot approximately and is it good for long range or close range or both please reply
well these are estamates(i dont have the gun anymore(it was more like a prototype for my new gun(thats y there are parts from other guns on here))) sniper round: shoots around like +50- deer slug: + 30- shotgun round: + 30-
How can a gun be a sniper and a shotgun just by different ammo. This thing doesn't even have a scope.
why does it need a scope? anyway, i meant that it fired like a shotgun as in it made a spread shot, and then like a sniper as in t fired one very accurate shot.
the thing is .............well............... sigh......... its nothing new to have the ability t fire like a sniper and a shot gun....... think about it....... one bullet for a sniper shot and 2 or more for a shot gun shot. almost every gun on this website can do this................. srry but really its not ahead technalogicaly of most existing guns.......................srry but thats the harsh, harsh truth that we must learn to live with.........................................
it is because the sniper bullet can shoot through carboard and the shotgun round can spray lots of ammo every were, no just in a straite line.
wo
Cool gun, I made it and it is very powerful. I got it to pierce paper at 15 feet (which is very good compared to other guns I built, so no offense). I am going to base my shotgun and machine gun design on your barrel, so which shall I post first?
i would like to see the machine gun. also if you post them please give me credit for the barrel and please put a like to this gun. also keep on the look out for the rifle. it uses the barrel but has many many more features. also the trigger is really light on the new verson and the system is more relistic.
Wow, awesome bayonet and I really like the hammer! That's amazing. Sure, I'll give you credit. When your new instructions come out, I'll be sure to build this gun!
thanks!
About This Instructable
5,327views
6favorites
Bio: Just your average K'Nexer/Programer/Nintendo DS fanatic. Any questions you would like to ask about any of the above? Send me a PM ... More »
More by dsman195276:K'NEX Pinball Machine! K'NEX Rail Car and Track NERF Sniper Pistol!
Add instructable to:
