3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DVD Shelving for $20 (ish)
I have quite a bit of DVDs and came to the conclusion that I needed some organization. So one night when I couldn't sleep I drew up a plan for an easy DVD shelving unit. It's 48" tall by 36" wide and holds approximately 360 regular cases. Of course, these measurements can be changed to suit your specific needs. I've decided to string multiple units together on the back wall of my loft.
Step 1Materials needed
Materials needed
Materials needed:
1x6 material in 6 foot lengths (5)
2x4 stud material at 36"
1 1/4" screws (28)
Wood Glue
I utilized the KREG pocket hole jig
Tools:
Saw
Square
Drill/Powered Screwdriver
6 comments
Oct 16, 2011. 10:49 AMdimtick says:
hey, nice simple shelves for what they are.
one suggestion. your base is to narrow for the height. very prone to tipping.
suggest using a 2x6 for the base. i see you noted attaching it to the wall. you should make sure to secure to a stud. if your securing to just the drywall then your going to want to use multiple angles to distribute the load. I also think it would be a good idea top secrew the shelving units into each other.
if you want to dress it up, run continuous 1x2's accross the shelves, then run 1x1 on the vertical edges and a good coat of white paint. the white will really pop against the blue wall and be really sharp.
if all your putting on those shelves is dvd's then there's no need for a 1/4 back panel but if you load it with that pile of books that i see in the photo then you'll want to add the back panel and screw it to the shelves. dvd's are a nothing load, but books are heavy.
Oct 16, 2011. 1:54 PMdimtick says:
Thanks for the quick reply. I didn't notice the date when I responded. I don't normally respond to old posts but this time I was using my iPod and thought it was new.
Glad those have worked out for ya. Shelves are one of the easiest projects and easiest to screw up if you don't understand how heavy what's going to be put on the shelves. Woodworking shows make these way more complicated than they need to be with dado's , rabbits, etc. Totally not needed. There are simple hand tool details that are just as strong and look just as nice.
One question
How did you clamp the shelves to the vertical when you drove in the pocket screws? I've had the problem if the boards aren't clamped really well that the pocket screws may not go in tight leaving a loose joint. I use plywood for shelves because my home center 1x boards are warped and crap. Maybe you don't have the loose joint problem with 1x's because the wood is strong enough for the screw to pull it tight?
Jul 15, 2009. 3:06 PMBedroomEmperor says:
Great job, and a good 'ible..! I have a few questions, though: Did you square the unit up before attaching the opposing side screws? Is that even a valid consideration when using the Kreg pocket hole method? Are there any risks of the unit suffering racking, due to to the construction? The unit looks great, and I may try this out for our collection, but I'm curious to know if this was a consideration for you. Of course, the point is moot if you are attaching the units to the wall, huh..?
May 18, 2009. 10:40 PMsensoryhouse says:
found by searching "kreg jig"
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:mennell
