Anyway - in the spirit of bigger and better for this year (theme being 'rock and pop heroes/divas') we toyed with the idea of re-creating the daft punk outfits from Tron Legacy...then we decided it would be too hard and take too long...but decided to do it anyway!
Materials used:
Approx 5 metres of 25mm EL ribbon and associated inverters per outfit
Suitable jacket and trousers
self adhesive mirror sheet
black chrome vinyl sheet
thin acetate sheet for the visor - also car window tinting film
2 strips of 'car sidelight' LED's - the ones that are supposed to make your ride look like an an expensive Audi
LOTS of duct tape
couple of 8x AA battery holders
wiring
2 x empty drink cans
plasticard and thin card
bendable metal strip
2 part epoxy resin
silicone sealant
thin copper tape
strong black foam double sided tape used for attaching car badges etc.
Tools:
scalpel
scissors
laminating machine
hairdryer
soldering iron / solder
sharpie pen
lots of tea
soldering iron
Step 1: - the helmet
I made a few adaptations but overall the method is pretty much the same...I cut the bottom from some coke cans to make the ears and covered the coke design up with mirror sheet - I also made a slightly wider rim around the visor as can be seen in the pics - this is to make the visor a little more secure, this needs to stand up to a day at a dance festival! So I'm not going to go in to massive detail on the helmet as it's already been covered - I'll include some details on the pics themselves but if there's anything you want to know - just ask :D
Step 2: - the jacket
- attach the end of the strip to a flat surface - like a window, with gaffer tape.
-Use the hairdryer to heat up the strip so you can peel away the backing of the strip to expose the underside - if you try without heating then it will just destroy the electrical tracks as you pull it off. With the backing off you can cut the angles required to get the shape on the front of the suit.
- connect each piece up with some of the foil tape before running it through the laminating machine to seal it back up again - as you look from the rear you can see the two tracks to which you need to make the electrical connections - on these long strips there is one around the outside of the strip and one down the middle - as long as you maintain these tracks with foil tape you can make any shape you like really...
To make the shorter arm and shoulder strips you just cut the strip to the length you want and then before resealing it put in two copper foil tabs one on each track - then when it's laminated cut a small square out from the laminating sheet with a sharp scalpel blade to reveal a patch of the foil tab which you can then carefully solder to, to attach the power.
I used A4 laminating pockets which were cheap but meant doing the chest pieces in sections but you can buy laminating material on a roll which would mean you could do it in one piece. You can't solder directly to the EL strip - anywhere you need to solder to you need a strip of foil tape...
Step 3: - the trousers
So I decided to make the trousers a little more simple than those you see in the original picture, but I still think the overall effect is pretty good.
I've included a few more detailed pictures concerning how to join the EL strip so check out the picture text for more info.
I've still got a few things to finish off including tidying up all of the internal wiring and routing it all into a bum-bag (not seen in the UK since the 90's, also known as a 'fanny-pack' hehehe) so check back soon...
Visit Our Store »
Go Pro Today »
make a offer
any instructions on how to make the Guy-Manuel helmet?
Helmet LEDs:
1. Could you see out of the helmet when you were done inserting the lights and they were illuminated? / How did you make that work?
2. What power source is required to run the LEDs? / How long do those car lights stay illuminated?
EL Ribbon:
1. Is "EL Tape" the same as the "EL ribbon" you mentioned?
2. Can you please provide the place you sourced EL from? (I need to order some, too!)
3. Is all of the EL lighting daisy-chain-connected to one battery source? / What type of battery(s)?
4. How long does it stay illuminated?
I know that's a handful of questions to answer, but I would REALLY appreciate your professional feedback and experience! Thank you!!!
Ok here goes:
Helmet
1.Vision is reduced by glare but with all of the LEDs placed towards the bottom of the visor (leaving a gap to see out of at the top) and shielding inside the helmet made from more black duct tape to block any of the light from shining back in to the helmet you can improve things - I also intend on putting a switch in to easily turn the eyes off when moving about - you could even wire this up to be in your sleeve/palm - then you could flash people! I think the nose vent design is also made to allow you to look directly downwards out of the gaps, beacause, well, you can!
2.The LEDs are rated at 12V - for my entire suit I have two 8xAA holders - one set powering the trousers and helmet and the other set powering the jacket - I've had the same set in throughout all the construction and testing process and I left everything powered on the other day and it ran for 70 mins before I turned it off with no noticeable change in brightness...
EL ribbon/tape
1. Yes, same thing!
2. I found a few sellers in China through alibaba.com and got a quote from a few of them - I've deleted the emails sorry so I can't give you the exact name...
3. All of the EL is connected to two inverters (supplied with tape) either soldered in or using 'Y' leads -'Y' leads are a hell of a lot easier!
4. Again, it's all powered off 16 AAs (suit and helmet) but it doesn't seem to be too scary on power consumption.
I need to update the instructable regarding joining the multi-piece strips on the front of the jacket and the thighs - obviously the joints are the weak point and I found that when the ones on the trousers particularly were flexed around the thigh it broke the contacts - the solution was to wire each piece of the strip individually with linking wires on the rear, that way each piece has it's own supply so hopefully won't fail - with hindsight I'd do the jacket ones like this too - It saves you messing about with tiny bits of foil tape between the sections too...more photos to follow soon...
I LOVE IT
its so cool being your brother!!!
