Step 3Picture time!
Since Becquerel Daguerreotypes have an equivalent ISO of about .0004, the exposure times can take a little while.
I can give you a general rule of thumb but many variables effect the exposure including your polish. In FULL sun with a well-polished plate, you should be able to get 45 seconds at f/5.6. This would mean that you're reading EV16 on a grey card. That's REALLY DAMN BRIGHT. For comparison, an exposure based on EV12 on a grey card would be about 6 minutes, 45 seconds at f/5.6.
Becquerel Daguerreotypes also suffer from limited dynamic range. While modern slide film or digital cameras can give you 7-9 stops of dynamic range, you'll be limited to about 3 with Becquerel. If you're metering a scene and the sky is 5 stops brighter than your subject, you're in solarization-ville.
Check out the attached PDF showing my cheat sheet for exposure calculations. I use this in the field and then adjust based on experience.
Add Comment
