Dainty Heart Earrings
480
9
Published
Introduction: Dainty Heart Earrings
About: http://www.etsy.com/sg-en/shop/EberhardtDesign
These dainty heart earrings are easy to make and give you the basics of making a dangle earring. These earrings can be found in the Eberhardt Design Store.
Step 1: Materials and Tools
Beads and Findings
  • Two (2) red heart shaped Czech glass beads (about 1cm wide)
  • Two (2) 2mm Swarovski crystal bicones
  • Two (2) denim Japanese Toho seed beads size 11
  • Two (2) antique brass finished hook earrwires
  • Two (2) antique brass finished 24 gauge ball headpins
Tools
  • Flush wire cutters
  • Round needle-nose pliers
  • Flat needle-nose pliers if needed for assistance
Step 2: Stacking the Beads
Headpins are used so you can stack beads and have a neat finish. 24 gauge antique brass finished headpins were used with a ball tip. The heart shaped focal bead was stacked first, resting on the ball ending. The Swarovski crystal and the Toho seed bead followed. The stacked beads are ready for to be closed with a loop.
Step 3: Make the Closing Loop
Bend the headpin about 1/8" (3mm) above the top bead. Using round needle-nose pliers make the bend slightly over 90 degrees. Reposition the wire in the pliers and wrap the wire around the pliers to create an eyelet. Wrap/coil the remaining wire around the 1/8" piece of exposed wire (picture 3).
Step 4: Cut the Excess Wire
Using wire cutters, cut off the excess wire from the headpin.
Step 5: Connect the Heart to the Earwire
Take the hook earwire and with the needle nose pliers open up the eyelet. Slide the assembled heart dangle onto the eyelet and with pliers tighten it up again. Repeat the steps for the second earring. The earrings are ready to wear.
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
