Step 14: Assemble Everything Together
Put everything in the back.  If you are going to plug in Danbo then you will have to cut a hole in the back, otherwise you will need to add a battery pack.
The base may need a brick if you plan on placing heavier items on the edges.  Since the head is large and the feet are small, this could tip if enough weight is placed on the edges.  I have not had a problem, yet, but my cats have not discovered this new table!
Have fun and play!!!!  Take cool pictures!!!!!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
