Step 8The Voltage Regulator
Now you have a convenient way of powering your PICAXE with a reliable 5 volts from the B5 block. As a safety feature for the PICAXE, it would also be a good idea to keep the 9 volts from the rover separate from the PICAXE in case while you are building and testing the circuit something gets connected the wrong way. Thus for this build you will use an H-bridge. It has special circuitry inside it that will prevent the 9 volts from the rover's battery pack from accidently passing through the PICAXE.
Add Comment
