3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dance Messenger
Step 2Programming the microcontroller
to program the microcontroller you will need the Atmel AVR ISP mkII programming kit (digikey part ATAVRISP2-ND). this connects between your USB port and the programming header on the circuit board. You will need the gnu AVR tool chain (http://sourceforge.net/projects/winavr/) to compile and download the code, or download with Atmel's free AVR Studio. the supplied code was written for the Imagecraft C compiler, but making it work with the gnu tool is simple.
The C code supplied does not include on/off button functionality, this should not be hard to add. you could also add a battery-voltage tester to sense when the battery is dead (this is important for lithium-ion, they are permanently damaged by discharging too much). to make a battery-voltage tester, you could (i think!) use a 3.0V zener diode and 220k resistor across the battery, and use the a-to-d converter on the mega8 to compare when the battery voltage falls below the zener reference voltage.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
524
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
