Dancing LED's
3,109
15
Published
Introduction: Dancing LED's
About: Indie game developer that loves arduino and LEDs and gaming and stuff.
Create LED's to dance to your music!
You will need:
• a small 8 ohm speaker
• code 104 capacitor
• 35v 10 uf capacitor
• LED (single- or multi-color)
• Audio transformer
• breadbord
• Audio cable
Step 1: Start the Build
Put the audio cable L/R in the rail's positive and the negative in the negative rail.
Step 2: Capacitor
Put the capacitor in the other rail so stop tearing in the speaker.
Step 3: LED
Add an LED in the same rail as the capacitor.
Step 4: Add the Transformer
Add the smaller coil on the led's rail.
Step 5: Finish the Transformer
Add the larger coil to the audio input rail.
Step 6: Add a Capacitor
Add the 10uf capacitor from the audio rail to the breadboard and connect a speaker to the same pin. Connect the negative of the speaker to the negative of the audio rail. Plug it in and play!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    3 Comments
    What is the rating? can you post me a link on the internet ?
    thank yoU!
    marC:)
    What is the use of an audio transformer? where i can get them?
    thank you!
    marC:)
    The transformer is used to amplify the audio signal enough to light up the LED. you can buy them at your local radioshack or similar. Hope that helped :D
