Dank Arduino MLG Clicker Robot
Published
Introduction: Dank Arduino MLG Clicker Robot
Hi guys! This is a cool robot that i have built.it is made for scoring points in the android game"illuminati MLG Clicker"
this may also work for "Cookie clicker" It is basically just a servo with a touchpen attached to it,that moves up and down very fast,which makes it tap the screen.I hope you enjoy :D
Step 1: You Will Need
1.An Arduino(any type)
2.A Servo motor
3.A Touchpen(or wet Q-Tip)
4.4 Jumper wires
5.Your smartphone
Step 2: The Servo
Glue the touchpen or Q-Tip to the servo arm as shown in the picture.
Step 3: Connections
Now hook the servo up to the Arduino as shown in the picture.
Step 4: The Base
Next,you need to build some kind of base for the servo,in order to hold it in such a way that the touchpen (or Q-Tip) touches the screen of your phone.For that,i have used some lego bricks.
Step 5: Almost Done
next you need to push the fourth jumper wire into the cotton of the Q-Tip (Or tape it to the touchpen if you are using one) and connect the other end to a GND pin of the arduino.If you are using a Q-Tip,you need to make the tip of it a little bit wet so it becomes conductive.
Step 6: The Last Step
The last thing you need to do is to upload the sketch to the arduino.You can edit the delay times between the moves for your liking.This is my first Instructable and i hope it was not too bad :)
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    2 Comments
    That's a cool idea! Thanks for sharing!
    Very clever! I was curious how you made the q-tip conductive. Nicely done :)
