Dark Sensor With LDR, Transistor and a LED
Introduction: Dark Sensor With LDR, Transistor and a LED
You wan't do a dark sensor with a LDR, one transistor and one LED and you don't know how to do it? In this small tutorial I will explain to you how you can do that even if you know only the basics of electronic.
Parts you need:
1 Breadboard;
1 Power source of 12v;
1 Transistor (in this case we use the BC547);
1 Resistor of 1KOhm;
1 Resistor of 680KOhm;
1 LED (in this case blue);
1 LDR:
Some condutor cables to connect the parts.
Step 1: Connecting Parts in the Breadboard
In the above image we can see the circuit we will construct. It's a simple electronic circuit and if you know how to do something on a breadboard, you should be able to do that dark sensor.
Step 2: Connect Everything
Just do the circuit like this and all should be working fine.
Remember, the LDR resistance depends on the light you have on the room or where you are constructing that. If you have light, the LDR resistance is low so, the LED should be turned off. When you obstruct the light that focus on the LDR, the LED should light up.
If for any reason your LED is always lighted up, try to chance the transistor. Switch the Emissor and the Collector. If the problem persist, increase the resistor you have in the base.
Step 3: All Should Be Working
Connect the power source you have to the breadboard. The positive pole in the red line and the negative in the blue line.
Try your circuit and see what happens.
Here's the video of my circuit working:
If you have any questions feel free to ask in the coments. If you think I should improve something, let me know. It's my first guide so it's normal I made some mistakes.
Kind regards,
Ricardo Silva
2 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Pocket-Sized Contest
  • Pro Tips Challenge
    Pro Tips Challenge
Hi, How can I use a power supply of only 5v?
you can use ordinary batteries
why only bc547 type of transistor is used why cant we try with anyother one?
use npn transister what you want it makes you job ,like 2n23904,2n2222,bc547,bc548,bc550,mbs8090,2n2369 ,etc
to check use protuse software
no more 680k is used use only 680k===10-50k;1k,or less than that
Hello. I just wanna ask, what are the use of every component in this circuit. Like why it has to be a 1k and 680k resistor? I need this for my finals. Thank you.
i made a very very basic circuit with just a led, a battery and e ldr but the leds turns on when ther's light and turns off in the dark? what could i possibly done wrong?
interchange the LDR and resistor
Is this can be used as study lamp or light house with some modification , basically I want to know how it can be modified for some other purpose, can you suggest some ? I do not have a good idea of all these things, just want learn and play, I am not from a electrical background .
