Anyone that has seen Star Wars knows Mr Kickarse 'Darth Maul'. He was different, he had a light saber that had a blade on each end. He didn't say much but you knew he was trouble. Wih this guide you too can be the silent one who looks like trouble. As long as Ewan McGregor doesn turn up with a Force FX your safe.
Step 1: Construct Blade
Initially I bought 5000mcd LED's assuming the higher the mcd the brighter the lamp. This has not been the case. Quite disappointed with the output of these I then took a gamble and bought 2000mcd with a much wider viewing angle and sure enough they are easily (appear) twice as bright as the narrow angle 5000mcd.
By bending the anode (long leg) at right angles at the very bottom you can solder it to the anode of the next LED which gives us about a 20mm spacing. The cathode can then have your resistor. Im my case I am running of 5 volts so use 150ohm resistor. Your could possibly run one resistor per 10 led's but due to manufacturing anomalies you may get varying brightness
Step 2: Construct blade Part 2
Once all the LED's are constructed and you have a plug on the end, it's time to find something to put them all in. Other sabers I have seen on the web use polycarbonate tubing. I'm on a budget and don't actually expect to be beating anyone with my saber so I opted for the cheaper acrylic.
The tube is water clear so with the LED's in place you can see each one light up which doesn't really give me the saber glow.
So some type of diffuser is required. I am still experimenting but I'm quite happy with clear cellophane that I scotch bright in various directions.
I feed the rolled up cellophane into the tube then feed in the LED's. Some care is required but the LED's are quite flexable in this condition so put up with a bit of abuse.
On the end I bought a plastic bung that fits in tightly so should prevent any moisture getting in.
Step 3: Ignitor Construction
I am using a PIC micro and darligton driver. For the PIC I am using the amateur friendly Picaxe http://www.picaxe.co.uk. These little beastys let the mad scientist out of everyone. Extremely easy to program with the free program software you can get up an running for as little as NZ$20. Initially I was using a 08M and shift register + darlington driver. Due to size constraints I opted for the big brother 18X to free up some real estate. If you make your own I suggest you make your hilt at least 40~50mm Dia so you don't have these size problems. For those not to electronics savvy (like myself) the LED's will draw current, not to much about 20mA. But 10 LED's will draw more current and 100 will draw even more. More than the poor old picaxe can supply. The 18X is cheap in the scheme of things I guess but NZ$15 is NZ$15 so if you were going to try and drive all these LED's at once it would work for an extremely short amount of time then become relatively useless. This is why we have a darlington driver. This chip is designed to drive big loads - it's it's job. If you get the 18X starter kit it comes with a darlington driver chip so your good to go immediately. The ULN2803A can drive up 500mA per output which is massive and can connected directly to the output of the Picaxe. This capacity is well above what we need so should do nicely!
The Picaxe, Darlington driver some resistors to make it all work and an 5 volt regulator fit snugly on my vero board. For the sound I found a site on the web that sells sound modules that make the fire up/down, wave and clash noise. I was tempted to record my own and interface it with the pic but with the time I have this was a quick fix. The pic turns the unit on and off so it works well for my application.
Click on the AVI below to see how the blade looks when it gets fired up.
Keep coming back more to come!
On this page are the Eagle schematics for the igniter board if you don't want to use variboard.
Step 4: Programming the PIC
The Picaxe I used was an 18X, this chip has 9 output pins and 5 input pins and can hold up to 600 lines of code. At this stage I only make use of the 6 of the output pins. 5 to run the LED's and 1 to turn on and off the sound module. At a later stage I could break the LED's up into 8 blocks for a higher resolution, remember my darlington driver can run up to 8 outputs at once. Or alternatively I could make the blade up of 4 blocks (Like another brand) and control each blade individually
All that said and done I can pretty much make the blades light up and down with about 20 lines of code. So what about the other 580? This seems a waste so I have added some extra modes 1. Normal mode, 2. Normal mode no sound 3. Night Rider mode 5. Pig mode. To change modes you hold down the push button for 5 seconds the saber flashes twice to signify program mode and depending on how many times you hit the push button with in 5 seconds dictates your new mode. If you don't press the button or press it too many times it reverts back to normal mode.
Here is the code that I have started with anyway.....
b5 = %00000001 ' Intiallise saber mode variable
b1 =0 ' Intialise mode change counter variable
b0 =0 ' Not sure why I did this
b2 = 1 ' Set the default mode to Saber normal
let pins = %00100000 ' Set pin 6 HIGH, LOW will turn on the sound module
Reset: ' resets all the pins after a mode change
pause 100
goto loop
loop: ' main loop checking push button
if pin2 = 0 then mode ??? jump to flsh if pin0 is high
goto loop
mode:
if b1 > 5 then mode_change ' if the counter is at 5 goto mode change
pause 20
if pin2 = 1 then decide ' if the switch is up goto select a mode
if pin2 = 0 then count_t ' goto counter
count_t: ' this counter will count to five
pause 10
b1=b1+1
goto mode
mode_change: ' flashes saber twice to signify mode change
b2 = 0
let pins = %00111111
pause 300
pause 300
pause 300
pause 300
count 2, 5000, b2 'counts bush button actions with in 5 seconds and stores this in b2
pause 300
pause 300
b1 = 0
goto loop
Decide: ' decision made depending on value in b2
b1=0
if b2 = 1 then saber
if b2 = 2 then silent_saber
if b2 = 3 then Knight_rider
if b2 = 4 then pigs
if b2 > 4 then saber
if b2 < 1 then saber
goto loop
saber: ' basic saber mode
b1 = 0
if b5 != %00000001 then p_down
if b5 = %00000001 then p_up
goto loop
p_up:
let pins = %00110000
pause 200
let pins = %00010000
pause 100
let pins = %00011000
pause 100
let pins = %00011100
pause 100
let pins = %00011110
pause 100
let pins = %00011111
b5 = %00000000
goto loop
p_down:
pause 200
pause 400
pause 100
pause 100
pause 100
pause 100
pause 100
let pins = %00000000
b5 = %00000001
goto loop
silent_saber: ' says it all really
b1 = 0
if b5 != %00000001 then p_down_s
if b5 = %00000001 then p_up_s
goto loop
p_up_s:
pause 100
let pins = %00111000
pause 100
let pins = %00111100
pause 100
let pins = %00111110
pause 100
b5 = %00000000
goto loop
p_down_s:
pause 100
pause 100
pause 100
pause 100
pause 100
b5 = %00000001
goto loop
Knight_rider:
if pin2 = 0 then reset
pause 100
pause 100
let pins = %00101000
pause 100
let pins = %00100100
pause 100
let pins = %00100010
pause 100
let pins = %00100001
pause 100
pause 100
pause 100
pause 100
goto Knight_rider
pigs:
pause 100
pause 100
pause 100
pause 100
pause 100
goto pigs
Eventually I think it would be cool to use a microphone or something and use the saber as a VU meter - Bring on the tri colour LED's!
manymodes.wmv289 KBStep 5: Hilt Construction
| 1-40 of 52 | Next » |
Not Nice
Visit Our Store »
Go Pro Today »
