Dash Cam Mic Upgrade
791
4
4
Posted in TechnologyGadgets
Introduction: Dash Cam Mic Upgrade
Here we'll be switching out the cheap microphone that cane with my budget dash can to an upgraded microphone capsule for higher sound quality.
Step 1: Gathering Your Supplies.
I'll be doing this upgrade to my c600 budget HD dash cam, but the idea and technique can be used with most any digital video camera, even if its not a dash cam.
Required tools:
camera
replacement mic (make sure you get one that will improve the sound quality, condenser mics come in many different levels of quality and size and without careful consideration it is possible to degrade the sound quality rather than improve it)
soldering iron
screwdriver
tweezers or small needle nose pliers
multimeter
Other helpful tools
files, drill, extra wire.
Step 2: Pulling Everything Apart
The first part of this process is taking apart the camera to find out what exactly your dealing with. In my camera, there are four Phillips head screws holding the front and back halves of the case together and you can see the different internal parts in the pictures above. In the last picture you can see the current microphone capsule around the upper left edge of the PCB next to my pliers. From here we can see what kind of microphone capsule would fit inside the case and if you'll need any other tools to make it fit.
Step 3: Picking a Microphone.
There are many different kinds of microphone capsules that can be used for this project. The Panasonic microphone capsules are pretty well known and is what I chose for my project. In the picture you can see three different kinds of microphone capsules, the one on the left is the original from the camera after I took it out, the one on the right is the replacement Panasonic capsule (the Panasonic is slightly larger, I'll go over some issues related to mic size later) and the larger one on top is a specialized vocal mic for high fidelity studio microphones, just for comparison. On some cameras, there will be a hole or slot of some kind that the mic will fit into, and in these cases it can be difficult to fit a different sized microphone into your camera. In some cases though, some careful shaping of the plastic or PCB with some drills or files can make the mic fit better, just be careful that you don't ruin the integrity of the case or your circuit board, there are so many different kinds of cameras and mounting methods of microphones that I wouldn't be able to outline them all in a single instructable, so I'll just show you the things I needed to do with my own camera.
Step 4: Switching the Mics
First you'll need to remove the original microphone capsule. This step is pretty easy, all you need to do is carefully pull the microphone capsule off of the pcb using your pliers or tweezers while melting the solder with your soldering iron, just be careful not to short anything with the melted solder or bump any other components with the soldering iron. Some through hole mounted mics may be slightly more difficult compared to surface mounted like my mic was, they just require a bit more patience. After you've removed the stock microphone, the next step in switching your mic is determining the positive and negative terminals of the mic input on your circuit board, if your lucky your PCB or mic will have positive and negative sides labelled but if your camera is like mine you'll need to test the connections. Some spare cable here can be handy, but not necessary if you can turn on the camera while the cover is off.
The reason for a positive and negative side to the mic is in how a condenser mic works. The microphone has a permanently charged side and a conductive diaphragm on the other side. As the diaphragm gets closer to and further away from the charged side, that charge pushes and pulls an electrical potential on the conductive portion of the diaphragm, turning sound waves into an electrical signal. Because the diaphragm is so small and can't move very far, the electrical potential this creates is very tiny, so most condenser mic capsules have what's called a FET in them, this stands for field effect transistor, and this transistor takes the miniscule signal created by the diaphragm and boosts that electrical potential to more usable levels. This FET need power though, so one pole of the microphone input will always be positive and the other negative, and the microphone has to be lined up so that the positive lead is powering the FET inside of the mic capsule.
The easiest way to determine which pole is positive and which is negative is to solder a pair of wires to the old mic terminal and lead them outside of the device, typically through the mic hole in the cover, so that way the device can be reassembled before being turned on. Once the cover is back on and the wires routed through, you can connect the other ends of the wires to your multimeter with some alligator clips. You'll have to turn your device on and set it to begin recording so that it sends power to the microphone leads, once you multimeter detects a voltage you can find out which lead is positive and which is negative. If the multimeter reads a positive voltage then the positive lead of the multimeter is connected to the positive lead of the microphone, if the multimeter reads negative then the opposite is true.
If you're feeling brave or in a rush like I was, you can try turning your device on while holding the leads directly to the PCB itself. I didn't have enough hands to get any pictures of this step but I would definitely recommend the wire method unless you're switching a really cheap budget camera.
Once you've determined the polarity, you can desolder the wires and connect your new microphone capsule in its place. Check the datasheet for your microphone capsule to find out which lead on the capsule is positive or negative. If you have trouble finding your datasheet or don't have a part number for the mic you're using, the lead connected to the metal case is typically the negative lead.
The process of attaching the new microphone will vary from one camera to another, but typically the mic is either held in place by solder to the board itself or is mounted to the case with wire leads to the board. My microphone capsule is simply soldered to the board so I held it in place with pliers while I soldered first one, then the other lead of the microphone.
In the case of my camera, there was a little extra work that needed to be done, the old mic fit in a groove in the top of the PCB, and the new mic was to big to fit in that groove. I tried placing the mic on top of that groove between the PCB and plastic case, but the mic was too thick, so I ended up using a file to widen the groove on top of the PCB. If you have to modify your PCB like this, just be careful and check your board for any traces near where you will be filing. Even if you leave enough copped trace without cutting the connection you could created a short circuit if the conductive metal case touches the newly exposed copper trace. depending upon the style of camera you may need to either modify the PCB or the case if your mic is a different size than the original. After I do a bit of experimentation with this and other cameras I'll add a few more steps for improving the sound and before/after recording of sound, both in the vehicle and in the closest thing I have to an anechoic chamber (padded storage room). Until then, I'd love to hear the experiences of anyone else who's tried a similar mod or any suggestions or requests for certain mods to include since I'd like to expand this instructable over time.
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    4 Comments
    Very cool. Perhaps something similar could be done to support an external mic.
    That does sound like a great idea. I'm currently getting my electronics "lab" set up in my new house. The wife and I are finally homeowners so I can set up my lab in the basement and my shop in the garage however I want to, which means I'm going to have a lot more time to work on projects like this one. I would like to get a couple more of these dash cams because I would like to do some videos while driving. I talk to myself driving all the time on the 40 minute commute to and from work through the countryside so it's the perfect time to just get some ideas on camera, and if I can get a good microphone and use them to cancel out noise between them I may be able to get some pretty good videos too. That'll probably be the next project after fixing my car.
    A lavalier microphone would be ideal for that. My interest is in recording sounds outside of the cabin, such as engine or exhaust. If only I could connect my ETM-001 to my G1W-CB...
