Step 5Try it out
If the suction does not stick, then you've bent your disk too much.
If the suction does stick and the GPS falls to the front, either you didn't balance the front well with extra adhesive or you did it too much and now the back doesn't contact the dashboard enough. Also, if the disk just pops right off the adhesive, you need a smoother disk to contact it.
If everything works, congratulations!
Protect your new mount by keeping the disk out of the sun - if the adhesive melts you'll have a bad time getting the melted part off, plus your GPS will fall down.
NE-Phil writes that the disk is easily seen and can motivate thieves! So I suggest putting some papers on your dash to cover the disk after dismounting the suction cup.
Add Comment
