This is a project I made a little while ago as a birthday present for my friend Daniela who introduced me to geocaching. It is based on several designs I saw in a book on spy gadgets. They would have been used for passing stolen documents and film between an agent and their handler, storing money and documents as well as other tasks.
I've just completed an Instructable for version 2.
Here's what you need to make your own:
Tools:
• Pipe cutter (optional)
• Hacksaw
• Metal working lathe with cross slide
• Drill or drill press (optional)
• 1/4 inch drill bit
• Mill and 1/4 inch milling bit (optional)
• Countersink (optional)
• Needle nosed pliers
• 1/8 inch diameter nail
• Applicator (and mixing dish if using 2 part epoxy)
Materials:
• 3/4 inch external diameter, 5/8 internal diameter, aluminum pipe, 3 1/2 inches long
• 3/4 inch internal diameter aluminum pipe, 1 1/8 inches long (The external diameter does not really matter. The piece I used was about 7/8.)
• Two sections of 3/4 inch diameter aluminum rod. One section 1 5/8 inches long, the other 1 1/8 inches long
• 8 inches of 1/16 of an inch diameter SS wire
• Epoxy intended for use with metal
• Strong string
Step 1: The sidewall and point (the body)
Cut the 3/4 inch external diameter pipe to length (3 1/2 inches). If you are using a pipe cutter be sure to round off the burr that is formed. This will make up the side wall of the spike.
On the lathe turn a 1/2 inch long section from the end of the 1 5/8 inches long section of 3/4 inch aluminum rod down to a 5/8 diameter.
On the lathe turn a point on the opposite end from the one you just turned down.
This piece will be the point.
These two parts make up the body.
The Lightning Stalker says: May 13, 2012. 5:18 PM
Might I suggest adding an o-ring. Unsealed caches are prone to moisture problems. Paper is great food for mold.
rouge.renard (author) says: May 14, 2012. 3:28 PM
I jut added that to my the design. Also, I would recomend using water proof paper.
schaude says: May 16, 2012. 1:07 PM
as a cheap waterproof "paper" you can use tyvek that sometimes can be found on envelopes or in kite stores. mostly it is white and one side of the surface looks like old paper or leather.
you can write on it and i saw printed symbols on it so once i tried to print on it with my old laserjet printer. the first attempt wasn't good - i printed on the surface side of the tyvek sheet, glued on a normal paper to make it more stiff. the result was the tyvek melted around the hot laser printing cylinder. fortunately i could pull the sheet away from the cylinder and the printer worked as it did before. in my second attempt i tried printing on the other side, being more flat, and it worked fine. the result was ok - if i didn't fold it too often the laser toner stayed stable enough on the tyvek - and it was water resistant!
sure... you can buy waterproof paper somewhere but i wanted to try this material. for my purposes it worked well so if you have an old pinter around and you (or somebody else) wouldn't be ashamed of it being executed give it a try!
Ben The Builder says: May 29, 2012. 3:24 PM
Tyvek, at least in big sheets (could be different but is still made by tyvek) comes in big huge rolls for water resistance when building a house, hardware and home improvement stores should sell it.
srilyk says: May 18, 2012. 5:57 AM
You could also take a look at the instructable for printing a map on plastic, if you were interested in printing stuff/waterproofing.
The Lightning Stalker says: May 31, 2012. 10:37 PM
Just don't try printing it with a laser printer. Hehheh.
Gilkar1944 says: May 13, 2012. 10:45 AM
I'm always interested in creating geocashing hides but these require a lathe which I do not have. Where can i find a way to make something similar without having to use a lathe? Maybe something like buying a piece of aluminum electrical conduit cutting off a suitable piece and hammering the end to a point.
rouge.renard (author) says: May 16, 2012. 11:00 AM
You could make the point by rolling a cone out of paper and taping it to one end of the pipe and then poring a small amount of resin in threw the other end so that it comes up to about 1/2 an inch from the bottom of the pipe. You could use a commercial end cap for the lid.
mrtidy says: May 14, 2012. 12:33 PM
Use PVC Pipe with the End caps.... glue one on and the other as a top that can be twisted and pulled off.. Even though it would be pretty much water proof if you also picked up a little tub of silicon grease in the plumbing dept that would pretty much water proof the cache... Cheap, easy to make and pretty much waterproof.
dasclown says: May 13, 2012. 3:41 PM
This will be weaker but maybe you can use the spike from those cheap solar landscaping lights.
criggie says: May 13, 2012. 3:21 PM
For little jobs you can use a drill press instead of a lathe. Slow and gentle helps, and making up a tool rest from some scrap wood and clamps is suggested. Also remember that the raw material is not supported so don't press too hard.
rallen71366 says: May 13, 2012. 5:22 PM
I've gotten by with just chucking a part into a hand-held cordless drill held in a vise. A file used to be called "a poor man's mill", and it works great for small jobs. I have access to a mill, and it's sometimes quicker to just clamp the part and grab a file than to do a real setup.
jamminstruc says: May 15, 2012. 5:46 AM
why not just use old prescription plastic containers? if you want to spike it use a peg and tape............easy to make and cheap enough........Thanks for a great article..........................................John G
ad5000 says: May 13, 2012. 7:32 PM
Just wondering here maybe for version 2.0 why don't you use a metal cigar tube and machine a pointed tip on the end instead of a flat one that way you could make them cheap and fast if you had to.
Just a simple thought I had!
rouge.renard (author) says: May 14, 2012. 3:32 PM
I don't know anyone who smokes cigars, but that sounds like a good idea. How thick are the side walls?
oliverkellow says: May 13, 2012. 2:01 PM
Cool, Very spygames.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
