Introduction: Deadmau5 Head
Picture of Deadmau5 Head
A couple of months before halloween 2013 I found a clean 11in pet ball for $2 so it was time to make a dead mouse head.
Step 1: Cut Out Head Hole
Picture of Cut Out Head Hole
Get a round object like a ball or something to mark the hole, than cut with your drimele tool. You may want it cut a bit bigger than your head because if you are going to let people try it on there head mite be to big that is what happend to my head so no only about 1/3 of people can put it on.
Step 2: Cut the Mouth Out
Picture of Cut the Mouth Out
Mark the mouth with electrical tape and look at the picture of the dimensions,you mite have to convert the dimensions if you're using a 11in ball like me because the dimensions are made for a 13in ball.
Step 3: Add Fiber Glass
Picture of Add Fiber Glass
This step is only need if you're using a pet ball not a lamp globe. I needed to put a sheet of fiber glass to make the bottom lip strong.It was weak because the air holes made it so there was only about 1/2in of plastic on both sides holding the lip on.
Step 4: Rock the Box
Picture of Rock the Box
Step 5: Cut Ears
Picture of Cut Ears
Refer to the size diagram and than mark your foam. I used 1/2in sheets of foam I got from a package. If you are using 1/2in foam cut 2 right ears and 2 left ears 4 in total.
Step 6: Glue the to Half of the Ear
Picture of Glue the to Half of the Ear
Sandwich 2 threaded rods or bolts between the 2 foam half's. To glue them together I used cocking you could use silicone or some thing that will not melt your foam.
Step 7:
Picture of
Step 8: Led Eyes
Picture of Led Eyes
I made 2 panels with 9 diffused white LEDs.Than cut holes in the globe for the LEDs to fit into.
Step 9: Lights to Music
Picture of Lights to Music
I used a tip 31 to make lights flash to music I have used the cuircut many times and in the project I used it to make the eyes flash to music.
Step 10: Electronics
Picture of Electronics
I used a candy tin to put the battery pack in. The cuircut has a switch which one way turns the eyes on solid and the other way make them Flash to music. I have a male head phone jack that plugs in to my ipod and a female head phone port that I plug a portable speaker into. I put the speaker and ipod In a very small back pack.
Step 11: Eyes
Picture of Eyes
It took me some time to figure out what to use for the eyes but evenly I found clear plastic Christmas balls for $1.50. I cut both eyes out of one ball with a drimele tool.than I sprayed the back side of the eyes with a thin coat of white which make the eyes shiny.
Step 12: Mouth
Picture of Mouth
I got lucky because my mom was going to put one of the strainer things in front of the house for free so I got it and used it as the mouth. I put my put of the plastic ball over the strainer and marked it about 1/2in extra and than cut it with the drimele. I bought some white leggings that I stretched over the mouth.
Step 13: Test Fit
Picture of Test Fit
It a good idea to make sure every thing fits and looks right before you start sewing.
Step 14: Sewing
Picture of Sewing
Making the pattern and sewing was the hardest part for me and this was my first time ever sewing so you don't have to be a master at sewing to do this.Sorry I don't have many picture at this stage.to make the pattern I found the top of head and than drew 4 lines so than you will use 4 equal pieces of fabric. I than drew a line bisecting to of the lines. Than drew lines every 1in on the bisecting line. Than measure the distance between the 2 lines every 1in and copy it down to paper. Cut out the pattern and than cut out 4 pieces of fabric,I used minkie fabric. Sew the pieces together, work it over the dome, cut out the mouth hole, fold it back and glue it.
Step 15: El Wire
I got 9 meters of el wire plus a driver off ebay for $8. Poke holes for the el wire.string it through. Sew the el wire to the head.
Step 16: Foam
Picture of Foam
Glue in some foam.
Step 17: Wear It.
Picture of Wear It.
Over all the project cost $20.I were it to school and than took it to halloween. On halloween night me in the mouse head and my dad in his jack in the box head took a loud speaker in my back pack to in and out and played gangnam style and danced to gangnam style through in and out.
icrack (author)2014-07-07
Sick
barbees (author)2013-12-02
Nice Halloween idea. Where do I go to get the tip 31 for the leds
rochassassin (author)barbees2013-12-06
Ebay,radio shack ,frys or pretty much any electronic place they cost about $1.50 at radio shack.
About This Instructable
5,251views
36favorites
License:
Bio: I'm 15 and have been working with electronics for about five years. I have been helping my dad fix thing's and make stuff ... More »
More by rochassassin:Flexidip your Rims120v lights to musicDeadmau5 Head
Add instructable to:
