Deadpool Tool Caddy
2,727
71
5
Posted in CraftArt
Introduction: Deadpool Tool Caddy
I made this more for fun than as an actual tool caddy. But I did learn a few things along the way. First and foremost sculpting is harder, really hard. Also spray paint and Plasti dip will absolutely destroy bare Styrofoam. Here is a video of the process:
Step 1:
I bought this Styrofoam head at the craft store for $5.
Step 2:
I am not a sculptor. But I thought I would make a few cuts to give him more of a heroic profile. I also defined the jaw line and I cut off the nasal bump between the two nostrils. After I finished all the cuts I sanded the whole thing with 320 grit sandpaper.
Step 3:
I needed to fill in the nooks and crannies of the Styrofoam so I smeared some wood putty on to the whole head. Once this was dry I sanded the whole thing and then reapplied more wood putty as needed. I would also dip my finger in water to help thin out and smooth out the wood putty.
Step 4:
This after 2-3 coats of wood putty and sanding in between each coat with the 320 grit sandpaper.
Step 5:
I added the "nib" as I call it to the back of the head, this is supposed to be the extra fabric of the mask that hangs loose. I wish I could have done this better it needed to be wider and flatter and blended in better. But ultimately considering the intended use for this I let it slide and pushed ahead with the project. I hot glued this into place and used wood putty to blend it in and sanded it smooth with 320 grit sandpaper.
Step 6:
I bought a pair of glasses from the dollar store and drew the shape of the eyes/lenses of the mask. The lenses just pop out of the frames with a little force. Just wiggle it back and forth and eventually the lenses just pop right out.
Step 7:
I used a Dremel tool to cut out the rough shape and then my belt sander to refine the shape. The last pic shows the end result.
Step 8:
I used white spray paint to pain the lenses both front and back. I also used a heat gun to add a slight curve to the lenses to better fit the contour of the Styrofoam head. I heated up each lenses while I held the end with pliers and then bent it over a smooth handled screw driver until I achieved the desired shape.
Step 9:
In this step I brushed on a layer of Mod Podge to seal the entire surface. This is important because spray paint will destroy Styrofoam so I made sure to get every nook and cranny.
Step 10:
Once the Mod-Podge was dry I sprayed the entire surface with Plasti-Dip.
Step 11:
Then I taped off the black areas of the mask prepping it for the red paint. I used a photo for reference as to the shape. There are many variations to the shape of the mask, I was shooting for symmetrical.
Step 12:
I used about 2 coats of red spray paint on the Styrofoam head.
Step 13:
Once the lenses were dry I hot glued them in place. I made a mount to hold the head in place. The mount is a 3/4 inch thick piece of wood cut in to the shape of a heart. It has a 1 inch dowel attached to it with a screw from the bottom. The head slides on to the woodedn dowel.
Step 14:
Now the fun part adding the tools to the tool caddy. Ideally I will use this to hold the different tools and drill bits that I am using for a particular project. As opposed to have them strewn about my garage and work surfaces.
Step 15:
This is impractical but it was fun to make.
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    5 Comments
    I like it! At first I thought it said toy caddy, and I was thinking, so Deadpool!
    yes, and right in time for the movie too!
    Great project! Very good Instructable. Lots of good ideas. Although you did not persuade me to see the movie, I will make a "head" of some kind. I think I will use it to hold a bunch of #1 X-Acto knives as an antenna toupeé.
