3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Death Becomes Her Halloween Costume
Step 3Building the video effect
  • last photo ←
It seems simple; two cameras connected to monitors facing the opposite direction. The greatest feature of this is that people can interact with each other "through" your body.
I needed my monitors to be powered portably, so I used 12 volt battery with special cables that were fitted with the monitor's power connector. I used the AV out cable that comes with the camera and connected it to the monitor's component in with a male-to-male RCA adapter.
Originally I was planning on using spy cameras that run of 9volts to provide my live feed. However, the $10 ones I received from ebay were crappy (duh) and died right away. I had to improvise and use what I had, and I happened to have two Nikon Coolpix digitals available. I cut pockets in the foam for the cameras to sit, and a hole for the lenses to pop through.
I decided that having the monitors in the cases was creating to much rigid bulk, so I removed them. I put them in the soft, vinyl cases that came with the monitors for attaching to the headrest of your car. I sandwiched them in leather and foam. This is the point where I damaged the second monitor, rendering it useless.
I cut a slit on the side of the foam where the cables attached to the monitor. This was so I could turn the power on and off easily. I could also turn the camera on every 30min (the longest default time it would stay on for).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:nicemag
