Debonucing Button on Basys 3, Xilinx FPGA Development Board
1,931
22
Published
Introduction: Debonucing Button on Basys 3, Xilinx FPGA Development Board
About: I work in the Digilent sales team and promote engineering education hardware to students, educator or who wants to learn engineering and technology. I like learning the new technology and hope people underst...
When you press a button, there is a chance that the button will not simply go from open to close. Since a button is a mechanical device, the contacts can bounce. (From Embedded Micro) For a short period after the button is pressed the value you read from an IO pin may toggle between 0 and 1 a few times before settling on the actual value.
To debounce a button, you just need to require that for a button to register as being pressed, it must look like it's being pressed for a set amount of time. In this case, being pressed is when the value of the button is 1. If you read enough 1's in a row it is safe to assume that the button has stopped bouncing and you can register one button press. If you fail to do this and you are using the button to increment a counter, then the counter may increase by more than 1 per button press since it will appear that each bounce was a separate press.
In this project, we will deb
Note: If you want to know more about clock domain, synchronization and metastability, you can visit the following websites:
https://filebox.ece.vt.edu/~athanas/4514/ledadoc/h...
https://embeddedmicro.com/tutorials/mojo/metastabi...
Step 1: Step 1: Input & Output Signals and Internal Variables
Input
  1. clk - Clock signal to synchronize the button input
  2. btn - Button pressed
Output
  1. LED - Light up LED when button is pressed
  2. dbsig - Output the debounced signal to the scope
  3. button_out1 - Output the flip flop 1 signal to scope
  4. button_out2 - Output the flip flop 2 signal to scope
Internal variables
  1. button_ff1 (reg) - Btn flip-flop1 for synchronization
  2. button_ff2 (reg) - Btn flip-flop2 for synchronization
  3. [20:0] count (reg) - 21 bits counter to increment when button is pressed or released
  4. threshold (constant /parameter) - Gauge how long the button should be pressed. In this case, we want 2ms, so the number we need to count is 100,000 for 100MHz clock
Step 2: Step 2: How Does the Logic Work
Firstly, we use two flip-flops (reg button_ff1 & reg button_ff2) to synchronize the button signal to the clock domain “clk”. When the push-button is pushed or released, we increment or decrement the counter “count”. The counter has to reach threshold before we decide that the push-button state has changed. We implement this by conditional statements:
Condition 1: Button flip-flop 2 (reg button_ff2) is high “1” and count “count” isn't at the count limit.
This makes sure that we won't count up at the limit. If this condition matches, we will count up (this means btn pressed)
Condition 2: Button flip-flop 2 (reg button_ff2) is low “0” and the count has at least 1 in it.
This makes sure no subtraction when count is 0. If this condition matches, we will count down (btn released)
Now, we need to decide when the button is pressed or not. To do this, we create a constant (parameter) “threshold” gauge how long button pressed to determine it is in pressed state. If the count is greater the threshold, the debounced signal “dbsign” will be high “1”. Otherwise, it will be low “0”.
We first simulate the logic and then scope out two signals (button_out1 and button_out2) through Pmod connectors to the Logic Analyzer and look at the timing diagram. In addition, we assign LED to debounced signal (dbsig), i.e. if the dbsig is “1”, LED lights up. Otherwise, it will be off.
Step 3: Step 3: Simulation
Follow the step to create the testbench and run the simulation https://www.instructables.com/id/How-to-Use-Vivado...
A 20ns clock is created and btn input is set as 0 and then 1 after 10ns. The dbsig and LED signal will be “1” at 2ms. Run the simulation at 20ms by change the simulation time (see picture)
Remember to create two procedure block (one always for clock generation and one for stimulus (btn)) to avoid any intra signal delay.
There is 30ns delay between button_ff1 and button_ff2. It shows in the simulation of button_out1 and button_out2.
Step 4: Step 4: Implemenation
Create constraint file from Vivado. Refer to http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug935-vivado-io-clock-planning-tutorial.pdf (see Lab 2: Post-Synthesis I/O Planning) and http://www.xilinx.com/support/documentation/sw_manuals/xilinx2012_2/ug945-vivado-using-constraints-tutorial.pdf for timing constraint
Then, run the synthesis and implementation and eventually generate bitstream file to program it on FPGA. (If you are not familiar with these two processes, you can take a look at https://www.instructables.com/id/How-to-use-Verilog-and-Basys-3-to-do-3-bit-binary-/ from step 8-11.
Step 5: Step 5: Timing Analysis Through Logic Analyzer
We port button flip flop signals (button_out1 and button_out2) and dbsig to Pmod port JC1, JC2 and JC3 of Basys 3 and then connect ports to Digilent Analog Discovery 2 digital channels 0, 1 and 2
Step 6: Verilog Code (design & Simulation) & Project File
Verilog Code:
`timescale 1ns / 1ps
/ Company:
// Engineer:
// Create Date: 07/17/2016 05:01:56 PM
// Design Name:
// Module Name: debouncing
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module debouncing #(parameter threshold = 100000 )// set parameter thresehold to guage how long button pressed
input clk, //clock signal
input btn, //input button
output LED, //LED output. Light up when btn is pressed
output reg dbsig, //debounced signal to logic analyzer
output button_out1, //flip-flop1 signal to logic analyzer
output button_out2 //flip-flop2 signal to logic analyzer
reg button_ff1 = 0; //button flip-flop for synchronization. Initialize it to 0
reg button_ff2 = 0; //button flip-flop for synchronization. Initialize it to 0
reg [20:0]count = 0; //20 bits count for increment & decrement when button is pressed or released. Initialize it to 0
// First use two flip-flops to synchronize the button signal the "clk" clock domain
always @(posedge clk)begin
button_ff1 <= btn;
button_ff2 <= button_ff1;
end
// When the push-button is pushed or released, we increment or decrement the counter
// The counter has to reach threshold before we decide that the push-button state has changed
always @(posedge clk) begin
if (button_ff2) //if button_ff2 is 1
begin
if (~&count)//if it isn't at the count limit. Make sure won't count up at the limit. First AND all count and then not the AND
count <= count+1; // when btn pressed, count up
end else begin
if (|count)//if count has at least 1 in it. Make sure no subtraction when count is 0
count <= count-1; //when btn relesed, count down
end
if (count > threshold)//if the count is greater the threshold
dbsig <= 1; //debounced signal is 1
else
dbsig <= 0; //debounced signal is 0
end
assign LED = dbsig; // assign debounced signal to LED
assign button_out1 = button_ff1; //assign button_out1 to button_ff1
assign button_out2 = button_ff2; //assign button_out2 to button_ff2
endmodule
/ Company:
// Engineer:
// Create Date: 12/19/2016 09:21:44 PM
// Design Name:
// Module Name: debounce_tb
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
module debounce_tb();
//Inputs in the module enable_sr. Need to use register type
reg clk = 0; //clock signal
reg btn; //input button
//Outputs in the module enable_sr. Need to use net type
wire LED; //LED output. Light up when btn is pressed
wire dbsig; //debounced signal to logic analyzer
wire button_out1; //flip-flop1 signal to logic analyzer
wire button_out2; //flip-flop2 signal to logic analyzer
// Instantiate the Unit Under Test (UUT) for module debouncing
debouncing uut(
.clk(clk),
.btn(btn),
.LED(LED),
.dbsig(dbsig),
.button_out1(button_out1),
.button_out2(button_out2)
// Generate the continuous clock signal. Wait for 10ns. Period is 20ns
always #10 clk = ~clk;
//Generate the button stimulus
initial begin
btn = 0;
#10 btn = 1;
end
// Need initial whenever we run finish or we need to include it in the begin end
initial
#4000 $finish;
endmodule
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
