Deck Gates: a Simple Wood Working Project How To!
Published
Introduction: Deck Gates: a Simple Wood Working Project How To!
About: There is nothing I love more then making something new and usable again that someone else would have thrown out or torn down!
How to build a simple outdoor deck gate! With our deck railings finally complete it was time to figure out how I was going to build the gates across the two entrances we have on our deck. My first issue was pretty obvious to me, I wanted them to swing entirely out of the way and remain open year around if we wanted them to be. I also wanted them to “match” the deck rails we had already made. So, I built my gate frames out of wood first!
Using 1×6 green treated deck boards I built two separate gates for the two entrances on to our deck. One of the entrances is over five feet wide but I decided to go ahead and make a gate big enough to span the distance anyway. I cut four boards per gate at a 45 degree angle. I almost used my jig kit for this situation but green treated lumber is pretty soft and forgiving so I just really carefully drove 3″ deck screws through the side and down the middle of my mitered corners.
Step 1: Hanging Them and Adding Conduit
With them built I hung them first using outdoor hinges before adding the conduit.
I made both gates just tall enough so the top of the gates hit just underneath the top rail both for looks and so that I could put a bracket there to grab and hold them so their weight would be entirely off of the hinges when not in use. I could only have one of the gates swing out like I wanted them both to because of the railing I had already built on one of the staircases. With both gates hung I then lined up my conduit to run exactly in line with the deck conduit and attached it with conduit straps.
I got a little creative with my latch situation because I didn’t want to have to buy extra latches. I bought three latches and then one gate got two tongues and one latch while the other gate got one tongue and two latches… Did that make any sense at all? It means both gates have a place to latch to whether they’re closed or open to take the weight off the hinges… and, in the end, I didn’t have any extra parts that I wasted money on.
Step 2: Completion
Joe and I do plan on having dogs again some day so, when that day comes, we’ll be using the gates a lot more and be glad we have them! We’re finally there guys, next week I get to show you our completed deck!
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    3 Comments
    First glue biscuit joiners or cut across
    the corners and glue a piece of ply in to strengthen the corners . These
    won't last long once the kids swing on them.
    Second put a diagonal cross brace top outside to bottom hinge side to brace the gate.
    This can all be done now so no need to dismantle.
    Like it, though I would have probably fallen for the modernish braided stainless steel wire for the dividers. I love how they look.
    I hear you about those braided stainless steel wires, they look amazing! Thanks for checking it out and commenting!
