Using a cool little program I dug up on the web, and a scanner I was able to decode the barcodes on the back of my NY drivers license, and find out what information people get when they scan it. I'm pretty sure that just decoding the barcode is not illegal, but some of the other things I describe probably are, so let those be just proof of concept.
All the times my license (well technically my permit, but its all the same) appears, I mess up the barcodes a bit so (hopefully) no one can get my information. Personally I don't care, but theres probably some good reasons why I should not let it out so I'm just being safe.
Remove these ads by
Signing UpStep 1Materials
1. Scanner
2. License/Permit from any state ( I think there are a few states ids that do not work, but most should)
3. Swipe Barcode Program
4. A Hex converter (more on this later)
5. Photoshop or similar program
6. Optional 1d barcode decoder
swipebarcode.jar85 KB| « Previous Step | Download PDFView All Steps | Next Step » |
It provides barcode solutions for .NET, Java, and Smartphones. Easy and efficient to use, so try them at following web sites. I do believe they are helpful to solve problems.
http://www.onbarcode.com/software/barcode_generator.html
http://www.onbarcode.com/products/net_barcode/
http://www.onbarcode.com/products/java_barcode/
I also need help changing the barcode on my license. Can you help?
Thanks
http://generator.onbarcode.com/online-qr-code-barcode-generator.aspx
http://generator.onbarcode.com/online-pdf417-barcode-generator.aspx
http://generator.onbarcode.com/online-data-matrix-barcode-generator.aspx
Also, you can use this barcode reader to check your encoded information.
http://www.onbarcode.com/scanner/
More barcode tools are also available here: http://www.onbarcode.com/products/net_barcode/. Hope it is useful.
There's an online barcode decoder that decodes 1d as well as driver's licenses. It's pretty easy to use - just upload an image and you get results. Also has an SDK if you want to integrate into your app.
Free Online Barcode Decoder
when in doubt check sourcefourge
I haven't tried your method yet, but, just for fun, I will try.
They could probably save space by having a standard order of values. Then the could fit more fun stuff on there, like "Suspected member of known terrorist group", or, "Kite enthusiast"
i got my cat for free in the mail years ago
http://www.cexx.org/cuecat.htm
http://www.intelcom.ru/download/decode/Decode417Demo.zip
It decoded it without even cropping.
Also, those of you that liked this post might want to check this out:
"I Am Not a Number — I Am a Free Man!I Am Not a Number — I Am a Free Man!†- about the scanning of ID's for the purpose of age verification at bars.
