3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Decode Your License
Step 3Legality becomes iffy here
http://www.cyanosoft.com/download/index.htm
Cyansoft makes a pdf 417 barcode encoder, which you can use to modify the barcode.
If you select raw bytes(you can also select hex if you want to use a hex editor to edit the information) on how the decoded information is shown in the pdf 417 reader, examine it and you should be able to pick out your information such as d.o.b, name, license number, etc. You can edit that information, copy the selection into cyansoft's barcode encoder, and tweak it to look like the original barcode. Some of the settings you may need to change are the Error correction level, the number of columns and rows, and the bar width. The overall purpose of tweaking the barcode is to get it to look and read the same before, just with the modified data.
To test out the modded barcode, export it as an image and run it through the decoder again, if it works great, if not just keep tweaking the settings in the encoder until it looks exactly like the original. You now have your modded barcode, but what should you do with it?
2 comments
Oct 7, 2008. 1:53 PMhjjhjhgjjh says:
IDK Think That Program works???
Feb 27, 2007. 7:11 PMpirateshockey411 says:
i need help editing information, m not really sure what the seets should be. i have a new york license if someone could tell me what the demensions i need to nter are that would be great
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
331
Author:Tetranitrate
I'm attending NYU-Poly.
