3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Decode Your License
Step 4From this point on everythings definitely illegal
Ive never tried these, so don't blame me if you screw up and ruin your license.
If you want to use the fake barcode you just make on your license, there are many possible ways to transfer it. The easiest is probably to erase the old barcode with some acetone and paper towels, and when your sure its completely erased, carefully print directly onto the license. The only problem with this method is that you would need a high density printer (thermal transfer or laser), and would have to be extremely careful that it printed in the right spot nice and cleanly.
Another method could be to clean off the old barcode with acetone, and then print out the new one on a transparency and affix it to your license. The problem with this method are that it would be easy to tell its fake, unless done really carefully.
Remember if you are changing a piece of information that is on the front you have to change it on the license too. It doesn't matter if the id scans 21, if it says 18 on the front they are not going to accept it.
(Note: Most licenses also have a 1d barcode on the back too. It contains much less information then the 2d barcode. To edit it you will need to find out what specific type of barcode it is, there are many sites online with pictures of different barcodes that can help you. Then download a decoder for that type, and decipher the information they give you, see if it matches up with your license number, dob, etc. Then change it and re encode it using a program for that type of barcode.)
1 comment
Jul 5, 2011. 11:13 AMcpushrod says:
Target store clerks will ask you for your driver's license when making certain purchases, such as games rated "M", but then they will scan it without warning you that they intended to do so. Show me where it says it's illegal to prepare a fake ID for the express purpose of preventing theft of your identity by Target. It's only a matter of time before they get broken into like Sony recently was.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
331
Author:Tetranitrate
I'm attending NYU-Poly.
