Introduction: Decoder Box
Picture of Decoder Box
This is a secret decoder box for a geocache or escape room. There is a 12 position rotary switch. I only use 6 of the pins (the other 6 positions act as an 'off' switch). You could use a 6 position rotary switch. In this case, I would suggest the addition of an off-on switch.
Position 1: Red LED is illuminated. (Switch is pointing to the #4 on the face plate)
Position 2: N/A (off)
Position 3: Yellow LED is illuminated. (Switch is pointing to the #2 on the face plate)
Position 4: N/A (off)
Position 5: Blue LED is illuminated. (Switch is pointing to the #5 on the face plate)
Position 6: N/A (off)
Position 7: Red & Yellow LEDs are illuminated. (Switch is pointing to the #1 on the face plate)
Position 8: N/A (off)
Position 9: Red & Blue LEDs are illuminated. (Switch is pointing to the #6 on the face plate)
Position 10: N/A (off)
Position 11: Yellow & Blue LEDs are illuminted. (Switch is pointing to the #3 on the face plate)
Position 12: N/A (off)
The code used 6 colours, each to correspond to a # on the face plate. 3 primary colours (Red, Yellow, & Blue) and 3 secondary colours (Orange, Purple, & Green).
Example:
You may have a combination lock with the colours Purple, Blue, Orange, & Green. This would indicate that the code is 6-5-1-3. Purple is made up of Blue & Red. When the rotary switch is pointing to the #6 on the face plate, the Red & Blue LEDs are illuminated.
Video:
[Play Video]
Step 1: Gather Your Materials
Picture of Gather Your Materials
Hobby Box - 3.17"L x 3.37"W - Digikey #HM1103-ND
12 position rotary switch - Digikey #EG1951-ND
Switch knob - Digikey #450-1736-ND
Red LED - Digikey #L10001-ND
Yellow LED - Digikey #L10007-ND
Blue LED - Digikey #5100H6-ND
9V Battery Holder w/ leads - Digikey #BH9VW-ND
3x resistors - 1000 ohm
6x diodes - 1N4001
9V Battery
Wire
Solder
TOOLS:
Wire stripper
Soldering gun
Drill w/ multiple drill & driver bits
Saw
Sandpaper or file
Ribstone Creek Brewery box
Step 2: Trim Switch Shaft
Picture of Trim Switch Shaft
Because my switch shaft was too long, I cut it down to the required length for my box and knob with a hacksaw. I cleaned up the edges of the plastic shaft with a file.
Step 3: Drill Mounting Holes
Picture of Drill Mounting Holes
Drill holes in the face plate for the switch. This switch has a small indexing stub beside the main shaft. Drill holes for the 3 LEDs. I don't have a picture of it, but the Battery Holder also requires holes.
Step 4: Solder LEDs & Diodes to Switch Pins
Picture of Solder LEDs & Diodes to Switch Pins
The LEDs push into place.
On pin 1: Solder the anode of the Red LED and the cathodes of 2 diodes.
On pin 3: Solder the anode of the Yellow LED and the cathodes of 2 diodes.
On pin 5: Solder the anode of the Blue LED and the cathodes of 2 diodes.
Step 5: Solder Diode Anodes
Picture of Solder Diode Anodes
Okay, in the last step we connected the LED anodes to pins 1, 3, & 5.
We also connected only the cathodes of six diodes to the switch. (two each to pins 1, 3, & 5)
Now we are going to solder the anodes of those six diodes to other pins in order to create the secondary colour combinations.
From the two diodes on pin 1 (with the Red LED), connect one of them to pin 7 and the other to pin 9.
From the two diodes on pin 3 (with the Yellow LED), connect one of them to pin 7 and the other to pin 11.
From the two diodes on pin 5 (with the Blue LED), connect one of them to pin 9 and the other to pin 11.
Step 6: Solder Resistors
Picture of Solder Resistors
The cathode of each LED is solders to a resistor. The other end of the resistors are soldered together to the negative lead of the battery holder.
Step 7: Schematic
Picture of Schematic
Here's my circuit diagram sketch I made for this instructable.
About This Instructable
1,914views
12favorites
License:
More by BlairCalgary:Decoder Box
Add instructable to:
