loading
Step 3: Scale Template down, Trace Main Body, Cut out on Band Saw
Next, take the same design template used for the top and bottom plate and scale approximately 80%, depending on how much of a ledge you prefer the top and bottom plat to have. If you want no overhang by the top and bottom plate, simply use the same template and repeat Step 1 with the 4 remaining pieces.
Before securing the four rough pieces with wood screws, throw some glue down where the heart will remain when cut out because you want the body to be a solid piece. I even put 3-4 screws along the heart outline, 1/4" from edge, spread out according to the image. This ensured that once the main body was cut out and a compartment cut out of the center in later steps the four layers would stay intact.
****Size of the wood screws depends on the depth of your layers, should be enough to secure each layer but not puncture bottom face. Otherwise it will not slide well on the Band Saw table, nor mesh with the bottom plate either. I used 2 1/2" screws.
My heart box body was made up of 4 layers which was roughly  3". You could choose to add layers in order to create a larger compartment, you're only limited by the size of your band saw. Space between the guard and table is the limiting factor.
Beautifull box indeed!
I must say that this was extremely well written and documented. I have a serious itch to go build one myself now. Your work looks beautiful. Great job.
Thank you very much. I think you should, it was a difficult but rewarding process.
About This Instructable
26,915views
140favorites
License:
Bio: I'm a mechanical engineering student at the University of Dayton. I love utilizing fundamentals and principals presented in the classroom to ideate and produce ... More »
More by lammerza:Shop Vac Hose Adapter for Free Heavy Duty Work Desk Hack an office chair into a "Hill Billy High Chair"
Add instructable to:
