Introduction: Decorative Origami Box
Picture of Decorative Origami Box
In this instructable I will show how to create a pretty origami box like this one. You will need:
-A square sheet of paper (15x15 cm is recommended, just make sure that it's square).
-A pair of hands
I hope this works for you!
Step 1:
Picture of
The first step is to take your piece of paper and crease through the middle (see picture) like a triangle. Then, crease the triangle in half. Unfold the triangle and crease the sheet of paper through the middle. Do not unfold this crease.
Step 2:
Picture of
Fold the flaps of the rectangle to opposite sides and press them down. You should get a triangle like the one in the picture.
Step 3:
Picture of
In your triangle, there is a hole (see image) at the bottom. Open up this hole, and press the two corners of the triangle flat.
Step 4:
Picture of
You should now have a square with flaps. Fold these flaps to the center. Repeat on the other side, and you should get a sort of kite shape.
Step 5:
Picture of
Open up the flaps that you folded to the center in the previous step. Press these down on all sides.
Step 6:
Picture of
Take the opened up flaps and fold them over the edge through the middle (see picture) on all sides.
Step 7:
Picture of
Turn your kite shape upside down and fold the flaps over, with once centimeter of space left. This is important to the next step.
Step 8: (Final Step)
Picture of (Final Step)
Fold the remaining bit of paper over to make a small edge. Insert your hand into the box to shape it and flatten the bottom. Congratulations, you've just made a decorative box to store some knick knacks in! I hope the tutorial worked for you!
seamster (author)2016-06-16
Very nice! Great instructions too. Keep it up! :)
About This Instructable
147views
2favorites
License:
More by LedditSnow.:Decorative Origami Box
Add instructable to:
