Picture it .. There is your honey, minding it's own business. Nestled snugly in its little plastic bear shaped bottle. All golden and see through. Then one day ... *BAM* .. your honey gets all cloudy and grainy. It stops taking your calls. It won't come out of the cabinet. And the big dance is coming up next weekend. *sigh*
Don't throw that Honey out just yet. It can be saved.
Remove these ads by
Signing UpStep 1: Salvation in one easy step
Put about an inch of water in the bottom of the double boiler and turn on the heat.
Put your crystallized honey into the top of the double boiler.
Warm the honey until the crystals dissolve.
Visit Our Store »
Go Pro Today »
http://www.instructables.com/id/Hottie-Totties/
As a matter of fact that is how they make creamed honey ( aka spun honey, whipped honey, churned honey, etc)
Don't let the name mislead you, it is actually finely crystallized honey.
It is made by adding a small amount of the creamed honey to a container of uncrystallized honey so that the small crystals propagate through the host honey.
"Do not heat honey in the microwave as this alters its taste by increasing its hydroxymethylfurfural (HMF) content."
and if it is on the internet it has got to be true :)
I haven't tried to microwave honey yet .. because the bottle was to big to fit in the microwave.
I don't know if the taste gets affected radically by microwaving, but I know it is fine if you warm it up on the stove the way I did, or by immersing the container in hot water.
While it is possible to burn what you are heating in a double boiler (especially if you let the water run out in the bottom pot) it is much less likely to happen than heating in a single pot.
I tried the running it under hot water method previously too .. took forever to get very little results. :)
I also tried submerging the bottle into boiling water. It worked for the honey that was below the water line but anything above the water took forever to slowly slide down and decrystallize.
