Deep Screen Dimmer
Published
Introduction: Deep Screen Dimmer
This may look like alot but the 14 steps are very short and, to-the-point
______________________________________________________________
This is a response to people wanting this from my previous video...
http://www.youtube.com/watch?v=DGvYbyz4swo
Your going to need:
1.) Visual basic (2010 express)
2.) >net framework Version:4.0......(comes with .net v4)
3.) the compressed files with source code
Have you ever used your laptop at night, or had a painful head ache? And that damn FN key just wont dim the screen any farther than you want? That is why I made this application in visual basic. What it does is overlay a black color over your screen (default 32%) to dim the screen past the black-light capability, and the best part is that you can click through it and use your whole screen as if the dimmer wasn't even there! to change the % of dim just click the deep-dimmer in the taskbar and hold: CTRL+SHIFT and while holding the screen will go completely black and you can then change he % and let go and return to a soothing screen.......
Step 1:
After downloading my zip file and extracting it, navigate through: "click through window" and then open "clickthough window.vbproj"
Step 2:
it will start opening and asking you stuff... just keep clicking NEXT and OK until you get to the 'Conversion done screen' and then click "CLOSE"
Step 3:
You will see a blue screen with stuff around it... find the file you want edit called: ClicktThroughWindow.vb (as in the picture bellow)
Step 4:
Now to start actually doing stuff!
That box you see is your application (I will call it the 'VISUAL)
*Start by clicking on an area of text on your Application(VISUAL) and fining it in the side bar (what the arrow is pointing at) DELETE THE TEXT NEXT TO IT.
*keep repeating this for all of the text seen on the visual. (the next picture will show you what it should look like)
Step 5:
Now that you Application is clear of unnecessary text you will want to click on the first Track-bar "to select it ."  (commonly called 'that dragging bar thinngy"...)
if you look to the bottom right you will need to change the track-bar's settings to
VALUE:        90
VISIBLE:      FALSE
the 90 can be what ever you like.... this is the dimness for when you hold the CTRL+SHIFT keys to modify the normal brightness (in other words just leave it at 90 to spot it out better)
Step 6:
You will now need to click somewhere on free space like at the top of the Application window to gain access to its settings from there look for: FORM BORDER STYLE: Sizable
and click by the right of the word "sizable"  for a drop-down arrow, form there find: NONE
and select 'NONE'
Step 7:
Now to change the background color to black for an adjustable dimmer color, here's how to:
*Look over in the settings and find: BACKCOLOR:  Control
again to right of 'CONTROL' will be a drop-down arrow, select the 'WEB' layout and find&select BLACK
8it should look like this now:
BACKCOLOR:        Black
Step 8:
Now you will want to change the size of you Application to fit the size of your screen....
*Find something that looks like this: SIZE:   336, 310
so change those numbers to your Width, height
***(be sure there is a comma after the width and a space after the comma!)
     Ex.
Step 9:
Now just drag the second track-bar to the bottom and scale it down to a manageable size that you are comfortable with. Your goal is to make it fit at the bottom-right of your task bar.....
but it can be wherever you want it to be
Step 10:
If you think that you got it where you want it, go ahead and click that little green play button at the top of visual basic. it will run your application and you can see if you like it.......
to stop it either close the application or click the little stop button next to play
Step 11:
After you click the play button hold CTRL+SHIFT. your screen should go black and your track bar should be visible.... while holding the buttons down drag it to the right or left  and let go of the keys you are holding.
*what CTRL+SHIFT does is make the application NOT-"Transparent" and clickable so that you can change the black-to-transparency level to your liking.
Step 12:
You can publish it now and make an installer... But some computer/Anti-virus systems don't like the installer.. so you can click the play button and open your task manager( CTRL+SHIFT+DEL) and find ( Click Through Window) and right click it and GO TO PROCESS
Step 13:
now it will bring you to the process and then you right click the process and clic: OPEN FILE LOCATION
Step 14:
now you are where the preview is running from, just copy everything there to someplace that you want it to be pasted.....
Now you have a portable screen dimming application that you made!
*you only really need these files thought:
Click Though Window.exe
Window Library.dll
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    6 Comments
    Hey guys, if it works for you post a comment and maybe some screen shots of it....
    Lol, The best way to save this program is to:
    1.) click "poject" tab and click at the bottom ".....properties"
    2.) in this menu click the "build" tab (on the left)
    3.) in the "configuration" drop-down, select "Release"
    4.) Under this is the "platform target" drop-down (I advise "any CPU")
    5.) Scroll down to "output path" and choose where you would like to save your program
    6.) Go back up to your tool bar and find the little green play button and change the drop-down to "release" and click play
    7.) let the program run, than close it. Now change it back to "debug"
    Thats All!
    (I think the author just did not know the proper way to save a portable version of the program "the above steps allow it to be portable on both x86 and x64 systems")
    One more thing the site below is owned my Microsoft and they give out free PROFESIONAL versions of Visual studio and more... They do this by validating your email only if it is a school e-mail (you must be a student) and they write it off as a charity like thing...
    https://www.dreamspark.com/
    I find it useful for those times you just want a dimmer screen. I just usually don't comment.
    Excellent. Thanks.
