Remove these ads by
Signing UpStep 1Disassembling the jigsaw
First, you need to remove the front cover on the jigsaw by prying it off one side and unwrapping it. There is just a post on each side that goes into the body of the saw to hold it on. Hopefully it goes without saying that you need to remove the battery from the tool before proceeding any further- if this is a revelation, you may really want to reconsider this instructable. Then all you need to do is unscrew the two halves of the saw case with a Phillips head screwdriver. Carefully pull the halves apart and make sure to keep track of all the screws- I'm pretty sure all of mine stayed in the body when I lifted it out. On the jigsaw the door for the blade store will come out and has to be put back in when you put the saw body halves together again as it is only held in place by the two halves being mounted together.
You will see the safety switch resting above the tool trigger switch, and it will simply lift out of the tool. If you look at the back of the switch you will see that it has a ridge in the middle that is right in front of a ridge on the safety switch, and that to each side of that on the switch there are pockets. The pockets let you move the safety switch to either side, depress the trigger and the ridge on the safety switch will go into the pocket. Without the ridge on the safety switch in place, the trigger can be pulled at any time with no interference, and since the safety switch is very simply removed we will remove it, and then remove the ridge from it. Also note what part of the switch would need to be removed to gain clearance above the trigger.
4
comments
Add Comment
pfred2
says:
wilwrk4tls (author)
says:
pfred2
says:
Add Comment
